Thread: Hose adapter for Rule pool cover pump?
    Sep 2015
    Bloomington IN
    27
    Has anyone been able to find a fitting that will work for the Rule 1800 pump cover at Lowes or Menards?
    I need this.... Amazon.com : Rule Replacement Garden Hose Adapter : Boating Bilge Pumps : Patio, Lawn Garden
    However, $10 seems like a ripoff and I need one quick.
    3/4" PVC is too small, 1" is too big.
    Thanks.
    Bill
    14000 Gal, Vinyl Lined Pool, No salt
    Re: Hose adapter for Rule pool cover pump?
    The fitting just pushes on. You could probably use a short piece of vinyl tubing or hose to slip over the pump connection part. Warming the tubing with warm water or a hair dryer can help get a good fit. From there, you could use a garden hose mender or slip the garden hose inside the tubing. There's not much pressure so no need for clamps.
    Support the site
    Sep 2015
    Bloomington IN
    27
    Thanks. I ended up finding a 3/4" to threaded adapter that I was able to dremel out the ID just a bit to get it to fit on.
    Bill
