Thread: after build questions
    Sep 2015
    Roseville, Ca
    16
    Hi-
    three questions-
    The picture shows a flow valve for the vacuum sweep protruding into pool. PB states that
    this is normal and they never get flush to the pool wall. Sounds crazy to me that a manufacturer
    would let a defect like that exist especially if it can be a safety issue. Is this common?
    Also; I turned on the pool filter to clean pool and sweep sides. The water flow was only coming
    out of the vacuum sweep valve but my other 3 flow valves were idle....
    Should I have water flowing from all valves when I turn on filter?
    One more: There is a slight opening where the concrete pool deck meets the ledge stone raised wall.
    Can that be a quality issue with water compromising this area over time?
    thanks for your help
    Tom
    TomCa - IG, gunite, Freeform, 30 x 17, raised beam wall w/ledgestone and flagstone cap, 3ft spill, radiant fusion blue frost, 480sqft concrete decking. SWG filtration, 2 returns, 1 skimmer. 2" & 2.5"PVC . JEP15 Jandy ePump 1.5hp Variable Speed, AquaLink PDA P4 Pool Control , SAVI-MELODY100-J Nexxus 14W 12V Pool Light X 2, J Series, Polaris - 360 Cleaner, Model F1B.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,569
    Re: after build questions
    when you say you turned on the "pool filter" to sweep the sides and clean the pool did you really mean your vacuum?
    I would like to see a picture of the "One more: There is a slight opening where the concrete pool deck meets the ledge stone raised wall. Can that be a quality issue with water compromising this area over time?"
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    Was Premier your builder?
    You are mixing language here and con fusing Kim.
    You have a pressure side cleaner. I,m not going to say the hose connection slight protrusion is acceptable but it's common.
    You tuned on the pump to run the pool sweep and All the flow is through the pool sweep connection. There is a jandy valve at the pad that controls the mix between the pool sweep and the other returns.
    Give us a picture for the other issue
    Jul 2012
    Tallahassee, FL
    30,569
    LOL it does not take much to confuse me!
    Kim
