Thread: Pool pump will not turn OFF
    May 2015
    Austin, TX
    118
    Something weird happened yesterday, i noticed that my pool pump was running all day. It completely ignored the programmed 6 hour run cycle. I went outside and tried to turn it off from the panel, switched it from auto, to service. Turned off pump switch. But no matter what i do pump continues to run. Eventually i flipped the fuse trip lever and cut off power supply to turn it off. Anybody have any tips on what might have gone wrong ? This equipment has been running fine for the past year since i owned it.
    15K gal, IG (I think its Vinyl not sure), 2 HP WhisperFlo pump, 60 sqft Pentair DE filter, SWG Hayward Aqua rite controller with t-cell-15, Aqualink RS6, Jandy Spa side 4-button, Polaris 280, 400K Pentair Minimax NT Heater Propane, test kit TF100
    Jun 2014
    15,096
    Re: Pool pump will not turn OFF
    Hello Sal512. While I may not be able to resolve your programming issue, it may help some others if you can describe what type of programmable feature you have (i.e. make, model, etc). Perhaps someone else will know a trick or two for that specific item. As for your note at the bottom of your sig (which test kit), I'd recommend the TF-100. You can obtain it from TFTestkits.net. It is filled fill generous amount of Taylor reagents. A great value. Best of luck!
    Sep 2015
    Mesa, AZ
    305
    What was the temperature outside? Pentair easytouch and variable speed pumps have a freeze mode protection. If the panel or pump goes into freeze mode, it cannot be turned off. The panel will display "freeze" on the display
    Freeform /620 Surface/110 perimeter/20k gal/ Raised bond beam/Baja shelf (2)//Pentair- Intelliflo VS pump, Pentair Whisperflo 1hp// Easytouch, C&C 520 Cartridge, Intellichlor SWCG// A&A- Magnasweep in-floor, LeafVac, Venturi Skimmer,// Mini-pebble (Aqua Blue w abalone shell)//4 Pentair Globrite LEDs//3 sheer descents//Travertine coping and decking.
    May 2015
    Austin, TX
    118
    It was day time and temp outside was 65. Yes, i have seen the freeze protection kick in whenever temp drop s below 38. This was not one of those times. I turned the fuse lever ON the next day and things started to work normal again. Whatever the problem was seems to have gone away on its own. I have the aqualink rs6 remote programming panel fixed to wall inside the house
    Jun 2014
    15,096
    Glad it is working again for you. Now we just need this screwy weather to settle down. Have a good one.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Faulty freeze sensor?
    Dolphin E10 Cleaning Robot.
