Results 1 to 9 of 9
Thread: RE: getting by with only 3% FC/CYA ratio?
    Dec 2015
    arlington, tx
    100
    has anyone heard of this ratio being adequate in prevent algae growth but only after removing phosphates from the water?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: getting by with only 3% FC/CYA ratio?
    Lower FC/CYA ratios can be used if you are willing to be diligent on continually adding expensive supplements to the water like Polyquat and in some cases even phosphate removers. But, this is really outside the realm of what we teach - "Trouble Free Pool Care". It's really not troublefree when you start worrying about your additives and if you have a sufficient quantity in the water. Do a search here in the deep end and you will find several threads about similar methods.
    But again, it's not what we teach. We haven't studied it.
    But, it is the purview of many pool stores, including a couple of large chains. They will be happy to sell you the products and advise you how they thing you should maintain your pool. But I will caution you shold you choose to go down that path - trying to mix pool store advice and TFPC advice won't work!
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, we've heard of it. It's an outlier in terms of regular simple pool care, and it's really not something we promote for that reason.
    Essential Links:
    Aug 2014
    Shallotte, NC
    693
    Using old "best guess" charts by Ben Powell, as CYA got ridiculously high, recommended chlorine got closer to 4%, but AFAIK, never below that. I've never heard the phosphates/chlorine thing before and every time I hear "phosphates" I get that itchy old feeling about pool store wisdom.
    The current recommended minimum of 7.5% was, I believe, worked out between Ben and Chem Geek and contains a lot of experience, wisdom, and chemistry. Going below that might be more of a headache than it is worth, if the pool goes unexpectedly green.....
    Donldson's Avatar
    NW Ohio
    2,916
    If I were to do that, I would probably lower the phosphate level while also maintaining a 50 ppm borate level. That should create an environment that is relatively uncooperative to algae growth.
    I personally wouldn't do that though. You probably wouldn't notice any improvement in water quality aside from the effects the borates would have on it. The active chlorine level of the FC/CYA chart is really so low that it is rare to have someone consider a lower level to be an improvement. I would think that the lower FC level could cause a higher CC level that would make the pool less enjoyable, but I haven't personally tried it so I could be wrong.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2014
    Shallotte, NC
    693
    +1 on the Borates.
    30,431
    Remember, please, what this forum is all about.....simplicity of pool care. Over and Over we prove that pools can be managed in a crystal clear status with FC and the correct amount of CYA. That's a flat fact and when you become interested in varying that, you invariably bring up complications that are not of interest to the main body of this forum.
    That's why this Deep End forum was created.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    "getting by" is the key clue in your thread title. You might get by, get away or get lucky with maintenance that way, but why not forgo the phosphate reduction expense and just use a higher, still safe and effective, FC level?
    Isolated Spa - 345 Gallons
    Dec 2015
    arlington, tx
    100
    thanks for everyone's help.
    i think i'll keep FC at least 7.5% of CYA despite my phosphate level being zero (as of today using taylor K-1106 kit).
