Thread: Blue spotting on white plaster
    I'm getting blue spotting on my white plaster. The plaster itself was redone last year and it started getting these blue spots late last summer. Chemistry is normal (chlorine). Its on both the horizontal and verticle surfaces. Anyone know what this is?
    15,300 gal., AG, sand filter, 1HP 2 speed pump, 40 GPM.
    Guest
    Re: Blue spotting on white plaster
    Please post a full set of test results. Without them we really cannot tell much.
    Butterfly's Avatar
    South Carolina
    10,045
    Have you had your water tested for metals?
    You're done SLAMing when:
