Results 1 to 10 of 10
Thread: Switch to SWCG?
    Jul 2014
    Manalapan, New Jersey
    98
    Switch to SWCG?
    New house with 7ish year old pool. It has a XG ClearVision water purifier. I was going to switch over to a salt water chlorine generator (had one in my old smaller vinyl pool). Heres the question, I dont see a place to put chlorine tabs (see pic), am I missing something?!? Is the clear vision need to be removed for the SWCG to be installed? Should I have it removed anyway, or just leave it? Anyone heard about the Jandy Pro Series TruClear™ Saltwater Chlorinator, their new salt system? Wondering if I should wait for that.
    23k gal in-ground gunite w/ spa/blower, Sheer descent, Jandy AquaPure SWCG, Pentair 2HP Pump x2, Raypak P-R406A-EN-C 399k BTU gas heater, Polaris 380/Polaris PB4-60 Pump, DE filter w/ separation tank
    30,421
    Re: Switch to SWCG?
    Well, if you are considering an SWG, you do not need chlorine tabs.
    (Wow! That's a complex arrangement!)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Switch to SWCG?
    I have no idea what a "XG CLear Vision water purifier" is. I tried my friend Google, but it keeps directing me to Nature2.
    I don't see an in line tab chlorinator in the photo, but I'll ask; Why are you asking for a place to put tabs?
    I think the installer retired on PVC and valve commissions on that install. Wow, I can't even follow the flow.
    Support the site
    Jul 2014
    98
    Re: Switch to SWCG?
    Yea, its not my install. Im coming from a single pump 11k liner pool w/ a SWCG with infloor cleaning system, to this. Im slightly confused! For a chlorine pool, dont I need somewhere to put cholrine tabs? This is the XG CLearcVision water purifier, made by zodiac/nature 2 (sadly with 3 feet of snow I cant go look at it right now lol.
    May 2014
    Franklin, NC
    9,184
    Re: Switch to SWCG?
    Well, that explains why Google kept taking me to Nature2. Nature2 by design is a "mineral" based pool care system. When they say mineral, you can read that to mean copper and silver ions. While they will kill algae, the replacment cartridges are an added expense you don't need and the side effects (staining of pool walls/turning blonde hair green) are things you don't want.
    If I follow the pipes correctly in your photo, the water exits the heater, enters the CLearVision than goes into the ground to be returned to the pool.
    I would remove the CLearVision and put a SWCG in it's place.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: Switch to SWCG?
    And at least empty the nature2/clear vision ASAP.
    Jan 2015
    Anthem, AZ
    188
    Re: Switch to SWCG?
    your system looks exactly like mine. rapak heater, vs pump, iaqualink....add the salt system and get rid of the jandy thing.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,516
    Re: Switch to SWCG?
    WOW at the pressure gauges! What do they "read"?
    You do not need a tablet feeder. IF you go out of town for more that a weekend you can use a floater.
    Kim
    Re: Switch to SWCG?
    The devices look like safety vacuum release devices. Looks like vac-alert.
    Support the site
    Jul 2014
    98
    Re: Switch to SWCG?
    Quote Originally Posted by JamesW View Post
    Yes, they're the vac-alert saftey releases.
