Results 1 to 11 of 11
Thread: SWG Chlorine Production
    Oct 2015
    Coral Springs, Florida
    79
    Had a Hayward AQR15 installed in September 2015. I've read the Pool School information thoroughly, and using the TFTest Kit, have kept salt, and chemical stuff within acceptable range. The beginning Desired Output was set by installers at 70%, that being normal for south Florida, they said. After 48 hours, the FC reached 14 ppm. Upon the advice of the dealer, I shut it off for 10 days, waited for the FC to come down to about 5 ppm. At that time, I checked the salt, balanced the chemicals, turned unit on, but reset Desired Output to 60%. Within 24 hours, the FC was, again, 14 ppm. Between that time, and the present, I've incrementally lowered the Desired Output setting until now I'm at 10%. Each time, after the FC ppm reached about 4 ppm, I checked the the water chemistry & salt to be sure all was within range. No matter what, the FC reached abut 14 ppm within 24 hours.
    I've a variable speed pump that runs 24 hours at three different rpm, but it is always on. I'm at a loss. Advice most welcome!
    30 x 15; in ground; about 16,000 gallons; Diamond Brite (applied 06-2015); Hayward AquaRite salt chlorination (t-15); Hayward filter (CX900-RE/PXC-95); Century V-Green 165 variable speed motor; all located in south Florida.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: SWG Chlorine Production
    First, is the SWG on all the time with the pump?
    Second, why so much pump time?
    Most pools in South Florida are inside a screen enclosure. Is yours?
    Instead of "within acceptable range", we really would like to see your test results.
    You should be able to cut that pump time down to 7 - 8 hours a day. With the savings from what you would normally send to "Florida Flicker & Flash" you can stop by Wings & Ale (4685 N University Dr) for a pitcher & some wings.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's likely your problem no doubt. Too much run time.
    Essential Links:
    Oct 2015
    79
    Have tried, for the past several months, all that you've so kindly suggested. Pump time reduced to 8 hours a day, at 3 different rpms. Pool is screened enclosed. When pump is on, SWG is set to 20%. Latest chemistry (3/25/2016) using the TF100 kit: FC:9.0 ppm; CH:300; TA:130; CYA: 40. And tim5055: How do you know about Wings & Ale? It's about 4 miles from our home.
    Oct 2015
    San Diego, Ca.
    648
    What is the FC level when you run the pump on medium for 4 hours at 20%?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Sep 2013
    Charleston, SC
    538
    Henry,
    I would suggest your raise your CYA level to 70-80 and you may even be able to decrease percentage and/or run time even more. The CYA level or 70-80 is recommended for a SWG.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Oct 2015
    79
    FC is 9+ ppm
    Thanks. Am in the process, and will post results any day.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    You might still have too much SWCG run time. I run my SWCG just short of 3 hours a day at 50% and it's still a little too much. I try to think of it in terms of operating time. 180 min operating X 50% output = 90 full minutes of generation. Still, I have to vary it with bather load, water temp, CYA, etc. It's going to move around some. Whoever told you to just run it at 70% should never be allowed near your pool again.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by Henry M View Post
    I worked in the area for several years. I was a happy customer.....
    Support the site
    Oct 2015
    79
    many thanks to all of you!! In an effort to raise the CYA, I've upset the pH levels, so have just added some boraxo (about 1 lb.) in an attempt to lower it.
    Well . . . next time we go there, I shall have a pint for you!!
    JoyfulNoise's Avatar
    May 2015
    13,231
    Boraxo is powdered hand soap which contains both borax and fatty acid emulsifiers. You should NOT put that in your pool.
    You want to use ONLY 20 Mule Team Borax
    Matt
