Results 1 to 10 of 10
Thread: Spa Cover Recommendations
    Oct 2015
    Austin, TX
    83
    My hot tub cover is getting heavy and I'm noticing mold or mildew between the cover and the foam. I think it might actually be rain getting in from above rather than vapors leaking up from below, but regardless, the cover is at least 5 years old, the stitching is about to go and I think it's time for a new one.
    Any recommendations on a new one? I'm looking at Solis. Every spa cover company I looked at have some complaints over at the Better Business Bureau but if they're making a few hundred covers a week then a few complaints per year is not unexpected.
    I'm also looking at the electricity savings vs increased R values and if my math is right it looks like I'll save about $20 in electricity over a 5-year period for every increase in R value. So if I'm comparing an R-20 to an R-25 then I would save about $100 of electricity with the R-25 over a 5 year period. That makes it economical to get the highest R value possible. Agree or disagree?
    Many thanks,
    Marc
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Re: Spa Cover Recommendations
    Darn I need another one too. Any research you can share?
    22,000 IG vinyl liner
    sand filter
    LQ 8 gallon
    Jacuzzi Hot Tub
    420 gallons
    Jun 2015
    Guntersville, AL
    5
    I would stay far away from solis. Ordered my last one from them. It took over 2 months to get the cover and about 6 months after getting it the whole center channel collapsed and the vinyl leaks developed leaks. Horrible experience with them all around. I wrote off all the BBB complaints and wish I hadn't.
    Sep 2015
    Columbus, GA
    1
    I need one as well. My last cover lasted for over 10 years, could have kept it longer but a friends kid decided to walk on it.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Hey there, I went with Hot Tub Covers Replacement Spa Covers from BeyondNice I had them sow 2 handles in the middle of the cover, so I could close the cover while in the tub.. The mistake I mad was not using both handles at the same time and they started to tear... Once I started using both handles no further damage has been done and it works great...
    Thickest Hot Tub Covers: 6"-4" Tapered with 1.0# (R23.85-R37) Cover thickness selectionULTRA cover is 6 inches thick tapering to 4 inches for the most insulation available - R24.9
    Tie down strapsStandard: 4 tie down straps, 1 strap on each of the four sides Tie down strap
    Additional insulationUpgrade: Long Steam Stopper - additional insulation seals under the fold View - $19.00
    Upgrade: Double Thick & Double Wrap - twice as thick as Standard and wrapped twice - $36.00
    1.5 pound - Shear strength 26-32 psi (Estimated 4-2 taper static load limit - 270 pounds) - $45.00
    Upgrade: Strengthen the fold/hinge View - $18.00
    Cost me 445 dollars with free shipping, received it in about 2 weeks from ordering.. Great customer service!!
    I have had this cover for 3 years now, it is still not water logged, does not let air escape, and still looks great (except the handles on the inside) It is thick, 6 inches in center and 4 on the ends.. way thicker than my original and that helps the heat stay in, the heater turns on much less now...
    Jul 2012
    Herndon, VA
    419
    I ordered a cover from hottubworks.com last summer. I went with the second cheapest cover, and it came to about $315. I received it in about 10 days from the order date.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Nov 2015
    Eagle Point Oregon
    102
    Great info. Thank You for posting, I need one also for Hot Springs Spa, will look these up for sure.
    pool 11-14,IG 16,500G 4ft to 6ft Quartz Tahoe Blue Pentair equip VS pump cartridge filter IC40 SWG Heat Pump Hayward Shark XL Robotic Eagle Point, Or
    Oct 2015
    Austin, TX
    83
    Thanks all! Anyone have experience with Spa Depot? I found generally good reviews here and a few other places. All of them have some info at BBB.org but it looks like Spa Depot tries to resolve... somewhat...
    Marc
    Sep 2012
    Pittsburgh
    35
    I just bought an acculok cover for my pdc spa. It is worth a look at their web site because the cover has sides with no split in the middle. So far it seems like a great cover.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I have a custom 3 piece SpaMate cover which they built for $550 delivered. This is a great price for a custom cover. I'm going on three years with no issues.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
