Thread: Switch from Bromine to chlorine in my hot tub
    Jan 2016
    TX
    5
    I want to switch from bromine to chlorine in my hot tub. Do I have to drain the water and refill. Also can I use the same filters i have now.
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Switch from Bromine to chlorine in my hot tub
    Welcome to TFP!
    You will have to drain as adding chlorine to your current tub will just convert the bromide back to bromine. The bromide will dissipate eventually but take an extremely long time to do so, so a water change now is the only way to quickly convert from bromine to chlorine.
    All of your equipment should be just fine with either bromine or chlorine, your filter especially so.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jan 2016
    TX
    5
    Ok thanks.
