Results 1 to 8 of 8
Thread: Freeze protection - plumbing - hydraulics - automation question
    Nov 2015
    Carrollton tx
    451
    I have jandy controls that are connected to 3 pentair vs pumps, they have freeze protection circuit.
    Also have swim jet pump, and cleaner pump.
    Vs pumps are for filter, spa boost and water fall.
    When it gets cold only the main filter pentair pump is set to come on. And it seems to ignore the programmed freeze protection setting. And it runs at whatever rpm it's programmed for for main filter use.
    Is there some hydraulic connection that keeps water moving in the other 2 pentairs when only one is on ?
    there is no freeze circuit for the other 2 pumps. I was told by one guy that he water drains out of those so don't worry about them.
    What would you do in winter in dallas ?
    Set all 3 pentairs to turn on at a low rpm ?
    Cover the other 2 pumps ?
    Use a drop light and a canvas drop cloth cover and call it done ?
    Thanks in advance
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Freeze protection - plumbing - hydraulics - automation question
    Based upon your current temps, I wouldn't even worry about freezing:
    Carrollton, TX (75006) Forecast | Weather Underground
    I am not a big fan of the automatic freeze protection and here is why: The Physics of Freezing and Freeze Protection
    I would only use it as secondary protection if at all.
    Mark
    Nov 2015
    Carrollton tx
    451
    thanks - but Im not worried about this week
    Im looking for information for the future
    Eventually Dallas will have a couple days in a row of freezing temps again
    If freeze protection is secondary to you, what is primary ?
    Like one of the responders in the thread you linked "I favor "defense in depth" approaches"
    Jul 2015
    Central Valley CA
    1,106
    I don't even think about it unless they start talking about a "hard freeze" and since that only happens a handful of times a year and only for a few hours at that it's not much of a concern. I did insulate the pipe to my water fall since it only gets flow when we are using it and I have my pump set to run from 4:30AM to 7:30AM for filtering which not coincidentally happens to be the coldest part of the day where I live. If you want extra insurance the drop light and a cover should work well and you don't need a big light either. When we go winter RV-ing in I use a strand of 100 incandescent outdoor mini Christmas lights and a hose cover I made with some Velcro and an old tarp I cut into strips and fashioned into a sleeve. The 35ft strand uses about 40watts, our supply hose has never frozen even when others we are with have.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Silver_2000 View Post
    Just tarping the equipment can drastically increase the time it takes for the plumbing to freeze even without a light bulb. But if the weather is severe enough to cause freeze damage (which is well below zero for more than 12 hours straight), then I would just drain the pad plumbing. It is much safer than relying upon automatic freeze protection and fairly easy to do if you have a filter with an air purge valve (just open it). We often get freezing weather here in the winter and I have never used automatic freeze protection.
    Mark
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    The largest thing I would suggest as Mark stated is to take a few minutes and learn about how to drain your equipment now while it's "nice" outside rather than in a panic when it's freezing. This is the only "fool proof" way to insure that your equipment does not freeze. Ten minutes now teaching yourself about your equipment will save you a TON of headache in the future IF worse case ever hits.
    Nov 2015
    Carrollton tx
    451
    I went with tarping because here the ground almost never freezes so The ground itself will help keep things a few degrees above freezing
    and if I leave the one pump runnning really low rpm in freeze protect mode that pump should create enough heat under the tarp to keep the rest a few degrees warmer as well
    Just looking for other options - ideas
    The Jandy filter has a bleed on the pressure gauge so thats easy as well
    Not sure if it will drain the pump baskets but I can test that this summer while its warm
    mas985's Avatar
    Pleasanton, CA
    11,737
    Air should enter the pump basket as long as the basket is above water level. There may still be a little water at the bottom but that is ok. As long as there is room for the ice to expand, there should be no damage.
    Mark
