Results 1 to 14 of 14
Thread: 30+ inches of snow on my pool cover. Now what?
    ashmoussa's Avatar
    Sep 2014
    Jefferson (Lake Hopatcong), NJ
    113
    Hi TFP,
    The blizzard here in the NE just finished dumping 30+ inches of snow on my pool cover (tarp style cover). Now what??
    Do I leave all the snow on top? Any harm doing so? I've heard some people would remove/shovel the snow off of the cover. That's the last thing I want to do after cleaning the front of my home.
    Will it eventually melt and overflow my pool?
    Do I pump off the water when it starts melting? And what if I have a few holes in the cover and it mixes with the melted snow?? Do I still pump??
    Thanks for all your input in advance!!ImageUploadedByTapatalk1453607890.954387.jpg
    May 2015: 17K Viking Caribbean Fiberglass IG pool (16'x40'), PAL lighting three 2T4 LED's (inside pool), Hayward DE 6020, Hayward Ecostar VS pump, SWG TCell15, Hayward HP21404T Heat Pump, Hayward Omnilogic automation + Sense & Dispense (HLCHEM).
    Rest of the backyard ideas/wish list: 12 x 20 Pergola, 48" Round Firepit, Accent/Landscape lighting, Outdoor movie theatre and music (projector & speakers), etc...
    Re: 30+ inches of snow on my pool cover. Now what?
    Down in MD, it looks like the snow has ripped our cover. Time for a replacement once the snow melts.
    22k gal, IG, re-plastered spring 2014, sand filter, main pump, + booster pump for polaris, Taylor K-2006 test kit, well water.
    Clarksville, MD
    May 2013
    Long Island NY
    419
    At this point I wouldn't worry about it. Mines the same way. And my back hurts.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Bummer about the ripped cover, an expensive replacement. I just googled it, and at 10-15 lbs per cubic foot, with 2-3 feet of snow, that's quite a bit of weight on a cover if the pool is drained down a few feet.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Jun 2014
    Roseville, CA
    343
    I think I would loosen up the attachments and let the snow berg sink as if you had no cover. It's just not designed to suspend that much weight.
    You'll save your cover, but you will sacrifice your chemicals and have a certain amount of organic mess, but that is part of opening up your pool anyway.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    ashmoussa's Avatar
    Sep 2014
    113
    My back hurts as well! Thank God for snowblowers!
    I read somewhere that the "tarp" style covers are installed in a way where they lay on top of the water. Then as the temps drop, the water freezes underneath and even though snow/ice/water falls on top of the cover with the frozen water underneath, it holds it up. True? False?Thoughts?
    As for the cover, it seems like every year I will be buying a new cover, which is perfectly fine. They are somewhat cheap anyway.
    So, when and if the snow starts to melt, what do I do?
    Stay safe and warm.
    Thanks again.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Ash, that is my understanding as well as far as saftety style covers are concerned...not sure about regular tarps without anchors...which kind do you have?
    If you have an anchored, true pool cover (with the strapping, etc.), I just want to reassure you that two years back I had the same amount of snow on my cover, did nothing, and all was fine
    Mine does have a mesh square in the center that, in spring, causes excess water to drain into the pool, overflowing if necessary.
    If yours doesn't, you may want to put a cover pump on it in spring.
    Stay warm!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    ashmoussa's Avatar
    Sep 2014
    113
    Quote Originally Posted by Swampwoman View Post
    Stay warm!
    Thanks Swampwoman, my pool cover is the plain Jane tarp looking secured with water bags. The cover is not on tight on top of the pool but kind of laying on top of the water (floating).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Pool? I don't see a pool out there. You sure?
    Essential Links:
    ashmoussa's Avatar
    Sep 2014
    113
    I know right!!
    And I took that picture early on as the storm was only half way done. Take a look now at the aftermath.
    ashmoussa's Avatar
    Sep 2014
    113
    If you look closely u can see the shape of my pool in the snow. Lol
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The frozen water beneath should hold the cover up so I wouldn't be overly concerned about the weight of the snow. Depending on the wet density of the snow, it could be about 5-20 inches of snow equals 1 inch of rain. What were the temps during the snow storm? Colder snow has a lower density, warmer snow as a higher density per inch. 5/inch equivalent of rain when warm, 30+ degrees, 20/inch when colder (<20 degrees). That will give you an estimate of how much water will be deposited on your cover when it melts. A cover pump wouldn't be a bad idea when it melts, if the cover is solid and does not allow water through. Mesh cover or cover with mesh spots = just let it melt.
    Isolated Spa - 345 Gallons
    Dec 2015
    Arnold md.
    92
    I too have a mesh safety cover and this was my first year with it. So far the 30" of snow has just melted through. Real problem is the dogs staying off of it...lol
    Vinny B
    New Pool Owner Nov 2015
    20x40 mineral set up
    ashmoussa's Avatar
    Sep 2014
    113
    Quote Originally Posted by vbertone View Post
    Lucky you!! My snow melted a very little but still quite a bit lays on top.
    I have the same problem with the dogs. Mine stay off of the cover, when no snow, and out of the pool, when uncovered. However, with all the snow they can't tell the pools there and have been leaving mines all over it. What's worse is trying to search for the brown bombs and dig them out with long poles and what have you.
    The neighbors think I'm crazy since every time I let them out I start screaming "NOT THERE!! GO OVER THERE!! NOOOOOOOOO!!!" Lol
    Oh well...
