Results 1 to 10 of 10
Thread: Measure and pour chlorine
    Oct 2015
    Winter Park, FL
    31
    Simple question...what do you all use to measure and pour your liquid chlorine? My chlorine comes in refillable 2.5 gallon jugs, so if I need to add 58 oz. (or whatever) what's the best and easiest way? Are there large measuring cups I don't know about?
    ~12,000gal. plaster, in-ground pool; Hayward cartridge filter; 1hp pump; Use Taylor 2006 kit w/ Speed Stir.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Measure and pour chlorine
    There are big measuring cups out there, like this one (just an example). 4 Qt. Clear Plastic Measuring Cup
    I would just cut down the top of a bleach bottle and use a kitchen measuring cup and water to figure out your 58oz, mark the side and just use that.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,231
    You can buy 1-qt plastic paint cups at any hardware store. The one I got from Lowes have hash marks on the side for every 4oz of liquid. It's not terribly accurate but it's convenient to get you in the ballpark. The cups cost about $1 each. I have one for acid and one for bleach. They are also handy for measuring out dry chemicals which I use a simple digital kitchen scale for assessing weight.
    This goes without saying but, always keep you chemical measuring equipment separate from other household items. It's just good chemical safety practice.
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,565
    I just use a plastic 2 cup measuring cup I got from the Dollar Store. One for chlorine and one of M. Acid. They stay with the chemical they are used for. Like Matt said they do NOT even come into the house to stay on the safe side.
    Kim
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I use measuring cups as well and I keep the cups with their respective chemical. Another guideline that works well for us in keeping cups used for chemicals vs. food separate in the event that a chemical cup is inadvertently not put where it belongs is that measuring cups for non-food use at our house are plastic or acrylic. Only glass measuring cups are used for food and these never leave the kitchen.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I usually round to the nearest quart or so and I just eyeball it. Each quart of 8.25% is 1ppm of FC for my pool. During winter I add either 1 gallon or 2 gallons to get it back above 10ppm. If you are reusing the same 2-1/2 gal jugs get a sharpie and mark off 1 quart lines on the sides of the jugs next time you empty them.
    With MA I usually add 1-2 quarts at time and I eyeball that as well. During summer swim season I usually add it a third of a gallon at a time, which drops my PH .3ish, so 7.8ish to 7.5ish is just right. I used to mark off thirds on my MA bottles but now I just eyeball it.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Many hospitals give out quart sized mugs with their logo on them to patients. They usually have markings to the ounce and mL up the side of the cup for accurate measuring of a patient's intake. I have a few of those that I keep in the pool/spa equipment for use with those liquids.
    Got any friends who work or are patients in the hospital???
    May 2014
    Clarksburg, WV
    331
    My pool usually takes about 40oz of 12% every day or every other day depending on use. So i measured in a clear bucket 40oz and put a black mark. I measured 30 oz and put a red mark, and 50 oz and put another red mark. If i'm low on FC i fill to the top red mark, if i'm high on fc, i fill to the bottom red mark. I'm never precise. I see ppl on here measuring exactly 22.5oz and pouring in. This method is supposed to be fast...lol So i just round to the nearest line. HAHAHA Maybe i'll over shoot my FC by 1 or 2 ppm, but in the end it all balances out i think.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I bought a 2 quart Rubbermaid drink bottle for our pool, works out perfectly. 1 ppm of Cl = 20 oz of 12.5% liquid chlorine for my pool, so I have the jug marked off at 20 oz, 40, oz, and 2 quart (64 oz).
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    wjr75's Avatar
    Jun 2013
    IL
    836
    I just eye ball it and pour from the gallon 12.5% jug. For our pool a one gallon jug will add 6ppm chlorine so if I need only 1.5ppm I eye ball a 1/4 gallon. When we close our pool in the fall I use a clear measuring cup to add the chlorine to the spa.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
