Results 1 to 9 of 9
Thread: too much HP?
    Sep 2015
    Orlando, FL
    33
    too much HP?
    Hello, In the process of building a 14,000 gallon SWCG with spa. There's a large spillway, with 4 waterfeatures. Also have an in-floor cleaning system. I thought a booster pump would be necessary... currently installed are 2 - 2HP (2speed) pumps.
    I'm just trying to identify what this pool will actually need for flows...I'm not planning on using the in-floor simultaneously with the other features.
    Any thoughts?
    Thank you
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,748
    Re: too much HP?
    You are building a pool, the pumps are already installed and you want to change them out? Or are you asking if you need a booster pump in addition to the 2 pumps?
    I guess I don't understand what you are asking. How about a picture of the pool features, pool equipment pad and a little more detail?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Sep 2015
    Orlando, FL
    33
    Re: too much HP?
    Pool is actually about 16,000 gallons. Features are 2 bubblers, 2 waterbowls, 5' spillway. What size pump(s) would you recommend?
    16k gal, IG, marcite, 3HP VSP Ecostar, 2HP Booster 2speed, 200 sqft cartridge, SWG, Caretaker IFC, Omnilogic, Solar, Taylor K2006, Born 3/16
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: too much HP?
    I'm confused also - You say " process of building" but that is contradicted by "currently installed are 2 - 2HP (2speed) pumps"
    Support the site
    Sep 2015
    Orlando, FL
    33
    Re: too much HP?
    Pool is not finished. Pumps installed. I'll definitely have increased water flow demands, but not sure if 4hp is overkill.
    Sep 2015
    Orlando, FL
    33
    Re: too much HP?
    Quote Originally Posted by bdavis466 View Post
    Total Volume including spa = 16,000 gallons
    Spillway is 5' across. 2 waterbowls. Fountain in Spa and Shelf. Infloor cleaner with 26 heads, Solar/Gas Heating.
    Most equipment is in, still need to Plaster. I originally planned for a VS pump + booster, PB suggested doing a 2speed 2HP pump over a VS.
    The PB has installed two Superpump 2HP, 2-speed pumps instead of one + 3/4 booster. I plan on automating with Omnilogic.
    Any thoughts on pump selection? I want good waterflow, but don't want to get a huge electric bill every month! Also, with the Omnilogic will I be able to dial in a preferred waterflow rate with the features. I'm guessing options will be limited compared to a VS pump.
    Thanks
    Mar 2015
    Sugar Land , TX
    424
    Re: too much HP?
    I have 8500 gallon pool, spa, and 3 scupper water feature. I use a Pentair 3/4hp Whisperflow for the water feature. I use a Pentair 3hp VS for pool, spa, and cleaner ( pressure side with booster ). I like that when I have water feature and spa on the appearance ( flow of water feature ) is not affected as it might be if one pump was running the system. I also like that I can dial in the speed ( with VS ) for daily circulation ( low ) , cleaner ( higher ), spa use ( even higher). My electricity is 5 cents per kw so it cost me to run 5 hours ( circulation 1700rpm ) , 1 hour ( cleaner 2800rpm ) about $5 per month.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    38,305
    Re: too much HP?
    With in-floor systems you need a lot of flow, so I think that pump be fine and allow you to run at lower speed when the cleaning is not needed. There should be no need for a booster pump.
    The automation will not let you dial in a flow rate, just select from the 2 speeds. You can control valves which could help dial in where you want the water to go.
    Sep 2015
    Orlando, FL
    33
    Re: too much HP?
    Thanks. I'm sure I'll figure it out once the pool is up and running. I'll have unions put in just in case I need to swap out equipment.
    My electric is about $0.10/kw , I read in another thread that the 2speed is usually the way to go if less than $0.20.
    Any other thoughts or recommendations before plaster?
