Results 1 to 10 of 10
Thread: Pool bench width - 12" or 18"
    Jul 2015
    Frisco/TX
    14
    Our pool digging starts tomorrow AM and the crew is outside marking the area of the pool. Looking at the marked area for the pool, it seems like our pool may not be wide enough. I was asking the project manager and he said that we could do 12" wide bench. The bench runs along the length of the pool on one side.
    What do you think? Stick with 18" or 12" will be OK? Attached is the design we are going with.
    Jan 2016
    Mesa, Az
    541
    Re: Pool bench width - 12" or 18"
    Your attachment didn't show up. My vote is 18 inches, but I'm a bigger guy and that combined with the coping overhang not allowing you to sit tight to the wall, the extra room I think is necessary. Not an expert in this regard, just my opinion.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    12" would seem too skinny for me.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2015
    Frisco/TX
    14
    I think it will too. Just wanted a little more width, but perhaps 18" will not make too much of a difference.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    How about something in between. Mine is 16, and it seems about right.
    chiefwej
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    I was thinking 16 is best. Most of our kitchen chairs and stuff are 15"-16".
    Jul 2015
    Frisco/TX
    14
    I think we are going to make the entire book wider by 16 or 18 inches. I think that will solve the problem
    I will find out tomorrow AM what it will cost us. I do like the idea of 16" as that would be good for the pool dimensions we have.
    Jul 2015
    Frisco/TX
    14
    We ended up extending the pool width by 18" and kept the bench at 18 inches. The PB will change $900 - $1000 more and I think it is worth is.
    Thank you all for your feedback. Otherwise, I would have gone with 12 inch bench and like all of you said, it would have been uncomfortable for adults to sit on.
    DFW, TX
    24,509
    Good plan!
    Oct 2015
    humble texas
    132
    I would definitely do 18. 18" is typical standard. That said my back bench is 18" where as my side bench is 28"
