Thread: Pool cover starting to get tight
    Apr 2014
    United States
    21
    Hello, when I closed my above ground pool, I drained below the skimmer but still plugged the skimmer. Well, the plug didn't do its job, and when the surface water began to freeze, I'm guessing it pushed the un frozen water up and into the skimmer. I didn't realize this was happening and the water in the skimmer froze and the skimmer body cracked. Anyway, my water level went down as a result. I had some water on my cover which is now frozen. But since the level went down in the pool, the ice is pushing down more on the cover and it's tight around the edges. It's not bending the frame, but there is a big winter storm coming and I'm going to have to shovel snow off the top. My question is, should I unclip my winter cover and take the string off that holds it in place, so it's not pulling? There's no chance the cover will blow away with the ice on top (yes I used air pillows and they are still inflated). Any thoughts are really appreciated. Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool cover starting to get tight
    Not speaking from experience mind you, but anything to reduce stress sounds prudent. Maybe someone will chime in with AG experience up there...good luck!
    Essential Links:
    rajung's Avatar
    Mar 2015
    Iowa
    185
    From my experience.
    I have no trees, so I go cover less now due to same issues.
    Release tension from cable that straps cover down and if possible flip edges of cover over top rail into pool area so no cable is under frame rail.
    Even if the frame doesn't get pulled in it will most likely rip the cover.I messed with covers for 3 years and continually removing snow from it after plowing,shoveling the driveways was a joke and not funny around here.As far as the skimmer crack? I disconnect the hose from it to the pump and the same with return fitting and cap skimmer and plug return.Congrats on keeping air pillow full of air.
    I never had luck on those POS.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
