Results 1 to 15 of 15
Thread: Construction Advice Requested
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    Have a couple of questions and hope you guys can help. Tried to provide some back ground for reference:
    Plaster - We are installing Finest Finish Arctic Coast Laguna. Picked this because the pebble tec on our first pool tore up my husband's delicate feet Filled the pool and it was more of a white Caribbean plaster instead of blue Laguna. Did a Traditional Start Up based on recommendation from PB. Gave it 7 days and still hated the color. PB and plaster sub said it was the color I picked and it wouldn't change much. 14 days after plaster and realized the plaster dust was terrible and aggregate was missing in large spots. Complained again and the plaster sub decided to do an Acid Start Up. Now the pool was Laguna! But the plaster dust and aggregate still looked horrible. So plaster sub decided to drain the pool and re-polish. After that re-polish, the finish was rough. So now they are grinding.
    Note - they re-plastered the spa after some plumbing fixes and it looks fantastic.
    Plaster Questions
    1. Long story to get here, but should I be concerned that 2 polishes, 1 grinding and not having water in the pool for several days will impact the integrity of the plaster?
    2. What is a reasonable amount of time/effort for plaster dust to go away?
    Inspection Question - It's late in the process, but we live in SW Austin outside of the city limits and permits are not required.
    3. Should we hire an independent inspector to ensure everything is up to standards?
    TIA!
    ~ Autumn
    16K IG FreeForm, 2 HP Jandy Stealth (Pool/Spa), 2 HP Jandy FloPro (Waterfall/Bubblers), MasterTemp 400 (Propane), 200 SqFt Clean & Clear RP Cartridge, EasyTouch, ScreenLogic, Zodiac MX6
    Finest Finish Arctic Coast Laguna Plaster Blend, NPT Silverstone Ocean Tile, NPT Jules Rustic Blue Marker Tile, Butterfield Harvest Wheat Rock Salt Finish Patio
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Re: Construction Advice Requested
    Quote Originally Posted by autjo View Post
    TIA!
    ~ Autumn
    YES!!! Especially for your electrical work, 'cause it can indeed kill you.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,408
    Do you own him any money still?
    YES I would have someone check everything!
    Kim
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    We withheld the plaster payment because it looked so bad. Also, realized last night that the spa re-plaster removed the marker tile. One more thing to deal with now!
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    Perhaps I am overreacting, but I really don't like that there are spots that have no aggregate showing. The areas in the pics are about 2 ft x 1 ft.
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    Here are some pics of the plaster dust. Plaster sub is saying that it will take 3-6 months with wire hand brush to make it go away. Not sure how I will hand brush in Feb in 6 ft of water. Does that sounds right?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Use a brush on a pole to reach the bottom. But, no, that is not right. The acid wash should have cleared the plaster and exposed the aggregate. It looks like they didn't acid wash enough in some areas. They should acid wash those areas to correct it. My PB fixed a couple of spots with the pool still full of water by pouring acid down a tube to the area and brushing.
    However, regular brushing and time, as they said, will also expose the aggregate.
    Jul 2012
    Tallahassee, FL
    30,408
    Easy answer for me ^^^^^^^^^^^^^ what he said!
    Kim
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    The plaster sub was pouring acid down a pvc pipe for several days with no real change. The only thing they manage to do was make the bottom rough. The Arctic Coast series is a polished smooth finish. I feel like this will be a never ending cycle since they didn't get it right the first round.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's not right, but you'll have to settle this with your builder. All we can do is sympathize.
    Essential Links:
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    Thx friends! Just feeling disheartened as the build has gone well, but now we're stuck dealing with the plaster sub and he's telling us there is nothing he can do to get the finish correct. We called a rep from Finest Finish and they are going to come out. FX we can get this figured out soon.
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    Plastered
    Update:
    Met with the sales rep and the finish is not correct so we will prepare for another round of polishing. Sales rep and installer are not concerned, but...
    Does anyone know if all this work will impact the longevity or PSI of the plaster?
    Apr 2013
    Sacramento, CA
    2,769
    Its taking off a layer so the plaster will have a shorter life. But that may not be material. Does not really affect strength unless they polish off too much.
    autjo's Avatar
    Jan 2016
    Austin, TX
    10
    Quote Originally Posted by gwegan View Post
    Thx!
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    Did this ever get resolved? Would like to hear/see the update.
    Also, could you PM me your pool builder and the plaster sub? I'm in Austin and dealing with a potential replaster after our Diamond Brite has completely faded after 8 years.
    Thank you
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
