Results 1 to 16 of 16
Thread: First test results after lowering high CYA
    Oct 2015
    Winter Park, FL
    31
    Bought my house in October of last year and it came with a pool. I'm from Chicago area, so I knew nothing about maintaining a pool. Luckily I found this site rather quickly and didn't get pool stored (or however you phrase it).
    Long story, short...once I got the green cesspool looking like a clear, celestial pool, I started taking tests. Found that my CYA was 250-300! From reading here, I knew to drain the water to lower it. That's been my obsession for the last 2 weeks...diluting and draining.
    Just last night did my pool finally fill up from, what I hope is the last partial draining and here's my test results using a K-2006 kit:
    FC: 6.4
    CC: 0
    Ph: 7.8 (best I could tell)
    TA: 90
    CH: 140-160
    CYA: 40ish
    How's these levels look? I know the CH is low and I'm in the process of adding some calcium chloride per the pool math's recommendations. See anything else I need to do?
    Funny story...when I went to the pool store today to purchase the calcium chloride, I brought a water sample for them to test so I could compare to my results (BTW, they were way off on some things). They always ask how the pool is doing. I told them my stabilizer has been way too high so I just completed a 50% drain and finally got it to where I wanted it (kind of knowing I'd get a reaction ). He immediately got upset and scolded me for doing that and said I basically screwed up all the chemicals in the pool. He says the CYA is MUCH too low and now I'll have to add all kinds of stuff to fix what I did and that I'll have a green swamp again as soon as the temp goes back up. My pool can't survive without chlorine tablets says him. I pointed out that using chlorine tablets would continuously raise the CYA levels and that on their literature, it says that if stabilizer is too high, a partial drain should happen. I asked him what he considers too high to be. He said to ignore what it says, that they disagree with their corporate's advice on where to keep the stabilizer level. And then he said this...your stabilizer isn't too high until it gets to the 2000-3000 ppm range , but until then, we can let it go! I almost laughed out loud. If I was more confident in my knowledge and abilities, I would have debated him as the store was dead, but I let it go.
    I'll get my chlorine from there and pool parts as I need them and a good laugh once in a while, but never will I take their advice! Thanks for all the great advice on here!!
    ~12,000gal. plaster, in-ground pool; Hayward cartridge filter; 1hp pump; Use Taylor 2006 kit w/ Speed Stir.
    30,432
    Re: First test results after lowering high CYA
    Nice work!
    Watch pH and keep it in the seven's
    What does your water look like?
    Oct 2015
    Winter Park, FL
    31
    Water has been crystal clear for over a month now. Love the way it sparkles in the sun. I'm just happy to have the chemistry in check now and I can really start maintaining it instead of battling it.
    Oct 2015
    Winter Park, FL
    31
    Just did another CH test an hour after adding calcium chloride and results came back around 220 +/- a drop. Is that acceptable or should I add a bit more?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Good job screwing up your chemicals! Numbers look good. Did you ask him how he tests for 2000 CYA? LOL!!!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Quote Originally Posted by Jpolsen View Post
    You will want to bring it up at least a little. With a plaster manually chlorinated (liquid chlorine) you wan to keep in the 250-350 range.
    Good work with the pool store. When I'm bored I'll take a water sample in to see what they say. Funny thing is, they always see something to try to sell me a product to "fix". I always just say "great, I have some of that at home".
    Support the site
    Oct 2015
    Winter Park, FL
    31
    Quote Originally Posted by pooldv View Post
    Every time I brought in a water sample, their tests always showed my CYA level being at 100. I knew it was much higher, but then when I asked about it, they said that's as high as it goes for them. I'm sure with a bit more knowledge, I could go in there and get them to contradict themselves with what they (don't) know. Good pool logic would eat them alive!
    When I'm adding drops and the red water starts to turn blue, should I interpret purple as red and keep adding or interpret it as blue and stop? This is why I say my CH is 220+/-.
    May 2014
    Franklin, NC
    9,216
    ANY drops base test should be done by adding drops one at a time until you observe no further color change.
    Are you using a speedstir?
    Support the site
    Oct 2015
    Winter Park, FL
    31
    No speedstir...it's all in the wrist! Just finished reading a sticky further explaining each test and it talked about the purple color...called it a "fading endpoint". With what you said and after reading that explanation, I believe my CH to be on the higher end of my testing range. I'll try again tomorrow.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    I was all when you said you took water the pool store then I was all when I saw his numbers! UNREAL!
    I very happy to see you have listened and learned. You will LOVE being here at TFP! I would LOVE for you to stay around and help others as they come here to learn so you can share what you have learned.
    Kim
    May 2014
    Franklin, NC
    9,216
    Because of the swirling involved in the test it seems to be more accurate when a Speedstir is used. I guess it has to do with the constant stirring.
    Support the site
    Dec 2015
    Southeast, PA
    42
    Quote Originally Posted by tim5055 View Post
    Funny thing is, they always see something to try to sell me a product to "fix". I always just say "great, I have some of that at home.
    Now that is funny! LOL I will have to use this!
    Nov 2015
    Riverside, CA
    40
    I love the speedstir! Got one for xmas and the measuring thingy that you drop into the vial to displace the water for accurate readings.
    My Pool: Guessing; 7,500g total, has a spa. WhisperFlo WFE-28 single speed, MiniMax NT 400 heater, Pentair Cart. CCP320.
    BIL pool: 16,000 total water, (650g spa). 3hp InteliFlo VS, Hayward heater (unsure of BTU), Hayward DE6000. full drain/refill on Nov. 25th, running BBB.
    Oct 2015
    Winter Park, FL
    31
    I may have to look into the speedstir and "measuring thingy"! I'm all about accuracy.
    May 2014
    Franklin, NC
    9,216
    I was on my iPad when I posted before and it's hard to set up links, so here they are
    "measuring thingy" - Sample Sizer
    SpeedStir Magnetic Stirrer
    I will just point out that most of us here recommend purchases at TFTestkits.net Why? Because when donations to keep the lights on here come up short, TFTestkits.net pays the bills and our electrons keep flowing.
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Support the site
    Oct 2015
    Winter Park, FL
    31
    I'm expecting some refills from tftestkits to show up at my doorstep any day now. I'm all about supporting places that provide a good service!
