Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
Thread: Is my new pump supposed to be this loud?
    Jul 2011
    Las Vegas, NV
    57
    I just had a pool built and yesterday was the first day they fired up the equipment to run overnight for shock, etc and I have to say this thing is LOUD - like I can hear it in almost any room of my 2600sqft single story home loud. I asked the pool builder about it and they said that it is normal, but i'm not so sure. If it is indeed normal, what can I do to mitigate the noise? It's located between a cinder block wall and my living room window, about 20' from the spa. It's a Hayward SP 3220EE, and according to the marketing it's supposed to be quiet but I guess that's relative?
    I've attached pics of the plates on the pump and motor and here's a link to a youtube of what i'm hearing all day: https://youtu.be/i7CYlt4PfSk
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Is my new pump supposed to be this loud?
    Sounds pretty loud to me.....how far is it from your patio-pool? Close enough to drive you nuts?
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Jul 2011
    Las Vegas, NV
    57
    Quote Originally Posted by smforte View Post
    You could say that. It's about 3' from my living room window and about the same around the corner from the patio and directly next to where the gas nipple is for my grill. Loud enough for sure to be annoying if just using the pool, the noise from the spa MIGHT drown it out but hard to tell yet.
    Here's a quick and crudely drawn (not to scale) diagram to show what i'm talking about. It's really rainy and cold at the moment or else i'd get out a tape measure but if I were to guess it would be roughly 10-12' from the corner of the spa to the closest corner of the equipment pad
    Dec 2014
    Riverside California
    482
    Did the PB at least give you the option for either a 2 speed motor or a variable speed motor? Either one would be a lot quieter that the single speed 2 hp motor.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Oct 2015
    Katy/Texas
    411
    Perhaps you can build an enclosure for the equipment pad.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Sounds like something is resonating. Try pushing down on the pump (or pipes) and see if the sound changes.
    Mark
    Jul 2011
    Las Vegas, NV
    57
    @gary300 actually they did not, and I didn't think to ask. Honestly didn't think the noise would be so bad
    @WASP that's what I was thinking, once I was sure it's not some other problem
    @mas985 I will give that a try tomorrow in the daylight, to me it sounds like when I had an above ground and got an air bubble trapped in the pump but i'm pretty sure they checked for that - they looked it over pretty good yesterday during initial start up and had someone else out today to make sure there's no more debris in the lines before putting in the in-floor cleaning heads (we had a bunch of dirt and some rocks and stuff come out initally). it's more the high pitch than the volume that is most bothersome
    A couple of observations.
    1) The pump does not look very new. Is it used?
    2) Why a total of 2.7 H.P? That's quite a lot. Probably too much.
    3) The base looks like a pre-made polymer base that is not well supported. That's going to vibrate and amplify the noise.
    Some ideas.
    1) Pour a solid concrete base.
    2) Get a variable speed pump.
    3) Possibly bolt down the pump to the concrete and put a layer of rubber between the pump base and concrete.
    Support the site
    wjr75's Avatar
    Jun 2013
    IL
    836
    Just had a new Pentair WhisperFlo installed last summer. Can barely hear it standing next to it which is 500% better than the old pump which had the bearings going out. People come by and can't believe how quite it is.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2011
    Las Vegas, NV
    57
    So I went out there and pushed/pulled on every part of the system and no change in noise. The pump is actually brand new, I watched them unbox and install it and it sure looked new then but it has rained a few times since then so that's probably what you're seeing. The base is a slab of concrete but not poured on site, all the equipment appears to be fastened down very well - there's no give at all on any components/pipes. The pump they speced out for our pool (12x28 3'6" - 5' deep), spa (7x6.5 3'6" deep w/6 jets, 18" above pool level), and in-floor cleaning system, I don't know if it's too much but everything seems to work great.
    Upgrading to a VS pump is not an economical option at this point because of the price of the pool build, but definitely something to keep a eye on for the future. I guess for now i'll have to try to come up with some way to dampen the noise with an external barrier of some kind
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by mas985 View Post
    I fear the noise is coming from inside the pump.... it sounds like cavitation to me.... not the rough vibrating gravelly type, but the "tiny bubble" type. I'm not a big fan of how short the suction side pipe is before it hits a valve and all of those ells.... and getting the water from your pool looks like it took another box full of ells..... If you could increase the pressure on the output side of the pump, it might shed some light on the cause......
    mas985's Avatar
    Pleasanton, CA
    11,741
    I have never heard caviation ever sound like that. All cavitation that I have ever heard in a pool pump sounds like gravel. Also, cavitation only occurs inside the impeller and you will never actually see it in a residential pool pump. So if by tiny bubble you mean something that you see, then that is an air leak and not cavitation.
    The high wine is a resonance of some sort but if it is not in the plumbing, then unfortunately it must be in the pump. Either a bearing or perhaps the impeller ring.
    But as was pointed out earlier, I don't think you need such a large pump or are you running a spa with it? If you have a spa, a two speed motor would be a good choice. If not, then you could downsize the impeller and that should improve the noise.
    Mark
    Oct 2015
    Katy/Texas
    411
    Good pump suction design is that you have a minimum of 10 pipe diameters of straight run of pipe to the pumps suction. That's just good engineering practice. Though I have yet to see it on the typical pool pump pad. If you want to hear what cavitation sounds like, briefly close the pumps suction valve, just for a few seconds. Also, as a completely separate item, you can pinch back the discharge valve to reduce flow and perhaps noise. As an aside, if you do not need all of the flow your pump is putting out, by throttling the pumps discharge you will reduce the amount of power consumed. Just don't close the discharge completely, you will over heat the pump seal.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by WASP View Post
    That is good engineering practice for pumps without pump baskets and is a hold over from the water distribution industry where the pipe enters directly into the impeller inlet. In that case, the extra pipe can have an effect in the water flow turbulence. Yes, some pool pump manufactures still recommend this for residential pool pumps but with a pump basket in between the pipe and the impeller inlet, I cannot see how that would make any difference as the pump basket is going to be the major contributor to flow turbulence into the impeller and not the pipe.
    Mark
    The 10x diameter rule is usually impractical and probably unnecessary with a strainer housing before the impeller. I think that it's more important to keep the water velocity below 6 feet per second. With that pump, the velocity is probably well over 6 feet per second.
    The base looks like it is not very solid. It's probably vibrating and amplifying the sound. The pump's frequency might be close to the base's resonant frequency. A poured concrete base should help quite a bit. Bolting the pump to the real concrete base with an interstitial layer of rubber should help as well.
    The pump is way too big. There's no need for that much H.P. A variable speed pump would have been a much better choice.
    Most of the time, you could run it low enough to barely hear. As needed, you could increase the speed to run the jets or in-floor cleaning system.
    I think that you're going to get tired of hearing the noise very quickly and that it's going to substantially interfere with your enjoyment of the pool.
    Support the site
    setsailsoon's Avatar
    Oct 2015
    Stuart/FL
    467
    Zollakk,
    It's kind of hard to tell from the video but it really doesn't sound that bad to me. No screeching, metal-on-metal sound so bearings and seal are not the problem. I've heard a lot of centrifugal pumps cavitate an yours is not doing that. Cavitation sounds like there are marbles rattling around in it. I also see no vibration issue apparent. Could be a leaf in the cooling fan on the motor is making it a little louder than normal. Or piping is in a bind (release the union on pipe connecting to the pump and make sure it's aligned properly). Last thing may be all the surrounding walls are giving you sort of an echo effect. If you want to reduce the noise I've used insulation blankets sold to provide heat protection for steam turbines with good luck to reduce noise to OSHA limits. You can probably get one from Grainger. Just make sure you don't block any of the cooling slots in the motor.
    I hope this helps.
    Chris
    -Chris-
    2013 In-ground plaster/pebble, screen enclosed, 12000 gal w/ Jandy 2 speed 1 HP pump, Jandy CS 200 cartridge filter, 800 gal spa w/ 1.5 HP booster pump, Solar heater, 2 LED lights in pool 1 light in spa, TF-100 test kit, The PoolCleaner Next Generation, Jandy RS-12 Automation system with iAqualink 2.0 control, Separate Hayward/Goldline Solar control
    Jul 2011
    Las Vegas, NV
    57
    Quote Originally Posted by CRB View Post
    Zollakk,
    I hope this helps.
    Chris
    Chris,
    Thank you for the input, I suspect you are right with the walls amplifying the sound after going through all other troubleshooting. I'll give your blanket suggestion a try until I can come up with something more permanent.
    I wonder if running the sound through a sound analyzer would provide any insight? I imagine that there would be some free sound analysers online.
    Support the site
    Oct 2015
    Stuart/FL
    467
    Zolakk,
    The blankets I'm suggesting are fire-proof and have kind of a silver reflective outer cover with wire mesh to hold it in place. We usually wrap and use banding to hold it in place. You need to do this so motor vibration doesn't allow it to slip over the cooling vents on the motor. I suggest you take some measurements before you go looking.
    Thanks for the follow up and please do let us know how it works for you.
    Chris
    -Chris-
  20. Back To Top    #20
    Qwaxalot's Avatar
    Jun 2012
    439
    I would try increasing the back pressure. If there's any valves on the return side, try closing them slightly. If there are no valves, try return fittings that are slightly more restrictive than the ones that are there.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
