Thread: New to this, getting bids now south Louisiana
    Jan 2016
    Hahnville/Louisiana
    5
    We are planning to build a sw in ground, lagoon shaped pool atapproximately 20k - 23k gallons. Our back patio has a courtyard with fireplaceand pergola. The look is old New Orleans with used brick. I have heard some talkthat suggest brick around the salt water would be a problem. Anyone with brick around sw? Any problems? I found a product that looks like used brick but is a new fired brick. All info and pictures are appreciated.
    Thanks!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Re: New to this, getting bids now south Louisiana
    Welcome!
    please post pictures of your yard and existing FP and pergola. It will help us visualize where things are going and what you are referring to. Also pictures of your plan, equipment with model numbers and all specs. This way you can get get expert advice from those "who know".
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Jan 2016
    Hahnville/Louisiana
    5
    IMG_0947.jpgIMG_1067.jpgThanks,Here are some pics of the existing courtyard. The arched opening in the brickhas water coming down from the top of the wall and trickling into the sugarkettle. I designed the everything myself and built the pergola. I had a masonrycontractor do the brick work. I want to carry this look to the pool and spa.the pool will be 8-10' off of the courtyard. It will be centered at the opening between the black pole support and the arched wall. The spa will be on the arched wall side. No particulars on the pool or drawing.Meeting with the contractor to view concept drawings this week.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Let me pause for a few and just enjoy the view!!!!!!!! WOW! THAT is so pretty! You do good work and have awesome ideas!
    As for the brick I have seen several pools with brick or brink looking coping. Some have SW some do not. I think as long as you seal them every once in awhile you should be fine.
    Kim
    Oct 2015
    Katy/Texas
    411
    Nice looking patio.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Really pretty space!! Can't wait to see how this all turns out!
    Denise-TFP Guide
