Results 1 to 16 of 16
Thread: Need advice on this bid. Seems high
    Exclamation Need advice on this bid. Seems high
    GENERAL SPECIFICATIONS:
    Pool Dimensions 35’ x 21’ Interior
    Pool Perimeter 112 linear feet
    Pool Surface Area 567 square feet
    Pool Depth – 3’6” – 6’0”
    Benches 16 linear feet
    Steps – 28 linear feet
    Sun Shelf – 84 square feet
    Spa Dimensions 7’ x 7’ level with pool beam
    Spa Perimeter – 28 linear feet
    Surface Area – 49 square feet
    Depth – 3’6”
    Tile dam wall, $10/ft allowance
    Total Gallons – 19,100 (adjusted for sun shelf & benches)
    APPROVALS – Phase One
    City permit – All fees and inspections included (if applicable)
    Insurance – Two million dollars General Liability Insurance
    Layout – Pool design will be marked in the yard for homeowner and city approval prior
    to excavation
    EXCAVATION – Phase Two
    Fence – Removal of fence as needed
    Rock – Complete rock excavation included
    Materials – All excavated material will be hauled away unless specified
    STEEL – Phase Three
    Pool Shell – 1/2” steel on 10” centers, both ways or per engineered plans (if applicable)
    Pool Bond Beam – 1⁄2” four bar beam
    Alternate Stress Bars – as needed
    PLUMBING – Phase Four
    Pool pipes –Schedule 40 PVC
    4 – 6 directional inlets, depending on pool design & environmental issues
    Pool Skimmers – Two Pentair independently plumbed for optimum control
    Pool Drains – Two VGB compliant Anti-Vortex
    Spa Pipes – up to 3” suction
    Spa Jets – six standard jets with rotating returns
    Auto Fill Line with Dedicated RPZ Valve
    Cleaner Line – one independently plumbed to 3⁄4 HP booster pump
    ELECTRICAL – Phase Five
    Complete electrical connection of all equipment and lighting
    Includes all in-ground service with all terminations, grounding, bonding & mechanical installation
    All electrical shall meet local and national standards including ground fault interrupters
    Lighting and equipment is bonded and grounded for safety
    Safety inspections included
    GUNITE – Phase Six
    Concrete – dry mix gunite rated to exceed APSP building standards
    12” bond beam, 8” – 10” floors
    All above grade walls to be 12”
    All exposed gunite and concrete to be underpinned
    TILE & COPING – Phase Seven
    Pool tile – 6” frostproof band at waterline
    Allowance - $10 per SF
    Pool coping – saw cut limestone
    DECK – Phase Eight
    Reinforcement – 1⁄2” Rebar on 10” centers both ways
    Deck material– 1,150 sf of spray deck
    Demo & remove existing patio
    Turndown beam – 270 SF
    Drainage pipes – as needed
    16 LF of limestone steps
    62 LF of raised planters with chopped limestone fascia
    Includes limestone screen wall for AC unit 8’ x 4’ tall
    PLASTER – Phase Nine
    Pool & Spa interior – custom mix mini pebble level 1
    CLEAN UP – Phase Ten
    Complete job site clean up
    POOL SCHOOL – Phase Eleven
    Pool Builder *edit* will provide a complete pool side Pool School to instruct the homeowner on the
    proper maintenance of the pool
    EQUIPMENT
    Filter pump – Pentair Intelliflo 3HP variable speed
    Filter – Pentair DE FNS
    Filter valve – Pentair 2” multiport
    Cleaner – Pentair Racer with 3⁄4 HP booster pump
    Automation – Pentair Screen Logic Bundle for mobile devices
    Sanitizer – Rainbow 320 automatic chlorinator
    Pool lights – two (white) Pentair Intellibrite 5g LEDs
    Spa light – one (white) Pentair Intellibrite 5g LED
    Spa Heater – Aqua Comfort electric heat pump
    Valves – premium brand valves
    Maintenance equipment – 16’ telescopic pole, vacuum head and hose, 18” brush, net & test kit
    WARRANTY
    Pool shell – lifetime
    Plaster – Lifetime on mini pebble
    Pentair equipment – three year manufacturer’s on part & labor
    Plumbing – three years
    Electrical – three years
    Sanitizers – Two years
    BY OTHERS/HOMEOWNER
    Reroute sprinklers and utility lines if required
    Pool barrier (fence) unless otherwise specified
    Door and window alarms, if required (2017 UL Certified)
    Landscaping, grass
    Upgrade or modify existing electrical or gas meter (service)
    Gutters and drains
    Water supply for filling of pool and for construction use
    Supply accurate property survey sealed by land surveyor (any additional surveys, fees or
    engineering that is required by City, HOA or MUD, will be homeowner’s responsibility.)
    Upgrade fence, gate, latches, railings & alarms to pool code
    PRICING (All prices valid for 30 days)
    $112,800
    OPTIONS
    Cabana/Kitchen – 23’ x 14’ cedar construction, T-111 cedar ceiling, electrical hook up for
    fan, 12’6” outdoor kitchen with two electrical outlets, 20 LF raised benches +$46,100
    Water Sheer Wall – raised 12” – 18” tall x 37’, chopped limestone fascia, one 18” water
    sheer, electric actuator for water control +$2,800
    Deck upgrade to travertine, level 1 +$13,200
    Jul 2015
    TX
    45
    Re: Need advice on this bid. Seems high
    Sounds high to me. Have you gotten any other bids? Best to get a few and compare. Just curious, what part of the country are you in? That seems to have a bearing on price fluctuation, but $113k..... sounds high.
    Quote Originally Posted by pool999 View Post
    I am in central Texas
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Sounds way high to me. Is there anything specific to the location that would make the build difficult (e.g., excavation by hand or rocky soil)?
    I just had a similarly sized and spec-ed pool built in the Houston area (see sig) for little more than half that.
    So something isn't right. But it might just be going prices for central TX.
    Definitely get another quote or two. Good luck!
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Jul 2015
    TX
    45
    Quote Originally Posted by tsmills View Post
    I agree with brdums, I'm in Houston and quotes I got were roughly half that for similar size/specs.
    Nov 2013
    Central Texas
    113
    Yeah little high for this area
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    Aug 2014
    Houston tx
    2,524
    If you could post pics of your yard and plans, that would also help. But I agree that seems pretty high.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That may be a bid from a super premium builder, but I think you can do much better. Please add your location to your profile, and enjoy the the forum. Good to have you with us!
    Essential Links:
    Apr 2013
    Sacramento, CA
    2,769
    Without knowing location, site constraints and seeing plans its impossible to really give an informed opinion. The one way to get reasonable pricing comparisons and opinions is to get a couple of bids from different contractors on the same basic plan.
    I am in Austin. It is a flat back yard, with as expected for Austin quickly reaching stone.
    I am aware of the decking being a healthy amount but was expecting 80K for this
    Jan 2015
    Austin, TX
    1,095
    I know this builder. They built my neighbor's pool and came highly recommended by them. It is a family/friends company and all employees are either family or friends of the owner. The person that does the quote also oversees your job. Plus they don't do that many pools a year so they can be selective with their pricing and I guess enough people pay their prices for them to stay in business. With that said they were my highest bid for the smallest pool. Your pool is bigger, has more deck, and has a spa. My quote was 65k from the same company. So given you are getting the spa, more than double the deck area, and more than 100sq ft of pool than what they quoted me. You can see their pool they designed for me in my build thread. It is on the first page.
    I think the pool they build is top notch but their quotes for such a high dollar have very basic materials. I chose to use another builder and while it was a big pain and it was obvious that this builder is more efficient and gets the job done I am way happier with the pool I got in the end than what they would have built for me.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Thank you for the response! I see that you read carefully to pull out that one line.
    Oct 2015
    Austin, TX
    83
    You should try to get at least one more quote. I know it's hard, we contacted 5 pool companies, we indicated that we had the money to pay for the pool that we wanted, and we got one quote after about 2-3 months of trying. Our lot is more difficult than most but still... pool builders in Austin can pick and choose.
    The rock in Austin is a beast. I would bet a large proportion of your bid is excavation. You also have a lot of deck and stone.
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    You really need to get more quotes so you know what your chooses are. That way you can get the best bang for you buck!
    I can't wait to see your build!
    Kim
    I would agree with the other posters here that it seems a little high as well. We are currently in the middle of our build with an Austin builder. We are in Leander. It is my second pool to build in the Austin area and I interviewed many builders between the two pools. Having just built our house last year and all the things that go with that as far as dealing with trades or contractors here, I can say that it is their market right now. There is so much construction and growth in this area that even getting someone to keep an appt. is a feat. Pricing is also just rising so I guess if we don't like it, there are others waiting behind us to give them business. That being said I am very happy with our builder and how things are going. Constant communication, onsite daily, many many years experience, and thanks me for the business every time he sees me. Keep interviewing until you get that comfortable feeling and good luck!
    My Build
    20K gallon gunite geometric, stonescapes mini Tropics Blue, 1400sqft travertine decking, 4ft stainless sheer descent, 2 laminars, 19x8ft tanning ledge with 50 pts light starfloor, 18x23ft cabana with outdoor kitchen.
    Quote Originally Posted by Atx1 View Post
    getting ready to do a new pool build (ugh). My last pool builder went bankrupt in a nasty way so Im looking for a new one and reviewing builder threads.
    I just wanted to add while the austin limestone is a pain it doesnt add that much to the build. It costs about 800-1000 for an excavator per day, it might take 2 weeks to hammer out the rock (but probably less) so about 14K plus dump trucks to haul all the fill.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
