Thread: Running the pump
    Jul 2015
    Poway, CA
    58
    Running the pump
    Quick question
    How long do you guys run your pump and what RPM?
    I have no debris that falls in the pool but I do have a sweep.
    Pool temp now 59, summer temp 87.
    Thank you.
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Running the pump
    We are all different. In summer, some only 4/6 hours per day. Most don't have VS pumps, although there are many. I'd say 2000-2500 RPM on avg. I run lower with a VS Pump, something like 1750 on avg.
    Essential Links:
    mas985's Avatar
    Pleasanton, CA
    11,741
    If you are trying to determine how long to run your pump, then I would suggest reading this:
    Pool School - Determine Pump Run Time
    And for more detail, read this: http://consensus.fsu.edu/FBC/Pool-Ef...on_systems.pdf
    Mark
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Pool school explains it best. I still have a single speed pump and do 4 hours in the evening and have had no problems.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2015
    Poway, CA
    58
    Excellent! Thank you!
