Results 1 to 8 of 8
Thread: Hard plumb question
    Hard plumb question
    I got a new 24' pool installed last year and the installers did not add any valves to the flexible hoses. I will hard plumb before re-opening this year. I plan to use union/ball valves and sch 40 PVC pipes. I know I need a valve between the skimmer and pump so I can clean the pump basket but I'm unsure if I need a valve on the line from the sand filter to pool return or if I need one between the pump and sand filter. Please share where your valves are located and how/when you use them.
    Brian
    24' above ground pool; sand filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Hard plumb question
    Unions do NOT forget unions!
    I have a valve every where something comes out of the pool-return and skimmer. I also have a valve for the back wash pipe so I can drain off water as needed from rain.
    I will take a pic when it gets lighter to show you.
    Just think of it like this............you want to be able to stop the water from coming out of the pool=valves.
    You also want to be able to clean your filter=unions.
    You want to be able to service your pump=union
    Post up your equipment and we can help that way also.
    Kim
    30,414
    A union between the pump and filter will allow you to easily remove the pump when needed.
    I'm unable to attach a photo. The pump/filter I have is:
    https://www.poolplaza.com/media/cata...ter_Combos.jpg
    The union/ball valves I was referring to are:
    https://www.lowes.ca/valves/american..._g1200289.html
    If I do not install a valve between the sand filter and return, will I lose water when removing the pump basket (assuming I closed the valve between the skimmer and pump)?
    Jul 2012
    Tallahassee, FL
    30,444
    Quote Originally Posted by witz07 View Post
    Yes you will as there will be nothing to stop the water from coming out the return to the filter to the basket. (ask me how I know LOL)
    You must put something in every opening that allows water in and out of the pool. Be it a valve or stopper of some sort.
    I would get unions for the filter so you can remove the top easier.
    Kim
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Yes, you will lose water. When you open the pump basket water will flow from the return, backwards through the sand filter and backwards through your pump and out the basket. I have a separate valve on every line that penetrates my pool's wall.
    Kim, you beat me to it.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Thank you both. I thought that might be the case but was hoping I was wrong.
    Jul 2012
    Tallahassee, FL
    30,444
    witz, If you have not already done so you need to "water proof" the area under and around your skimmer. I dug down about 3 inches and put rocks THEN put pavers on top of that making sure to not touch the pool wall. That way when (notice I did not say if) you overflow the skimmer or a pipe/hose comes loose it will not wash out your pool bottom.
    Kim
