Thread: Kreepy Crawly Racer
    Apr 2015
    Katy, TX
    65
    Kreepy Crawly Racer
    I read that we should remove our robot pool cleaner when we add chemicals. If my pool is balanced and all I'm doing is adding chemicals (ie: liquid chlorine, MA) to keep it balanced, do I still need to remove the robot. It's just a hassle to have to remove the robot, add the chemicals and then place the robot back into the pool. I mean, we add chemicals daily or every other day.
    24K gallon, IG, plaster, Pentair Clean and Clear Plus Filter, Pentair Heater, Pentair Intelliflo pump, Built in March 2015, Taylor K-2006, Spa included
    Mar 2015
    Sugar Land , TX
    424
    Re: Kreepy Crawly Racer
    I do not remove mine. Saying that when I add acid I dilute first in pail of water then pour in deep end away from cleaner.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
