Results 1 to 10 of 10
Thread: Natural gas heater help
    Jan 2016
    Canada
    39
    Hi folks,
    First time poster and new to pools! We bought our home early last spring and inherited an unground 32 x 16 lagoon shaped pool. The heater (Laars?) conked out on us mid summer after giving us a lot of trouble right off the start. We wasted hundreds of dollars trying to fix it.
    Anyhow, we tried solar blankets but Canadian summers are hot and miss and so we'd like to get a new heater, leaning towards a N. gas. I don't know much about solar or other heaters - would they be worth a try? Heard the gas heats fastest and might be best for our climate.
    The brands I see most often are Hayward and Raypack but others are available. Should I go with an electronic model or manual one? Should I choose one brand over others? Or is there much difference? We are willing to spend a bit more of the brand can give us more years and better reliability and overall cheaper service. I would also like to get a very efficient model.
    So, having given some background, what would you folks recommend? Should I bother even considering solar? I am not too keen on the panels as I find them to be an eyesore... also, I have read that initial investment cost is very high.
    Thanks in advance for your input!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Natural gas heater help
    Welcome to TFP!
    Raypak seems to be a crowd favorite on TFP as far as brands go. Generally, gas is used for quick heating, spot heating or special occasions and heat pumps are used when planning to keep a pool heated all of the time to maintain a temperature.
    Solar panels can definitely heat a pool. South or southwest facing panels is a must, especially for your latitude. I don't know how well solar could work in your climate. Hopefully, some more "northern" folks can chime in on solar.
    Aug 2014
    Northern IL
    4,615
    I agree on the Raypak!
    Jan 2016
    Canada
    39
    Thanks folks... the company that serviced my heater last year mentioned Raypack too.. typically mid to high 80s and low 90s aren't uncommon in July and August.. but some years it can be cooler...our summers are much like Michigan (I'm in neighbouring Ontario).
    I just don't think we have the cash outlay to buy the solar.
    How long should I expect the Raypack to last? Should I go with a manual or electronic model?
    thanks!!
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Manufacturers quote a unit to last 7-10 years but your mileage may vary with many factors involved.
    Do NOT get the milivolt units. Many places don't even allow these units to be installed as they have standing pilot lights and it is a waste of gas. So get the electronic spark ignition. You won't be disappointed.
    Raypak all the way!
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    +1 ..
    Factory Warranty Station for:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I have Rheem...which is a Raypak.
    Essential Links:
    Dec 2014
    Riverside California
    482
    +2. Get the Raypak, most trouble free brand around.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Splaker
    Solar Blanket, Well Water, Borax Added. 68
    Jan 2016
    Canada
    39
    Quote Originally Posted by Kiss4aFrog View Post
    Thank you everyone... And Raypack it is!
    Cheers
