Thread: Cleaning & painting concrete deck
    Aug 2007
    NC
    27
    I'm going to paint the concrete deck around the pool. It's never been painted. I'm considering the Quickrete Multisurface Concrete Sealer. They recommend cleaning first with their product called Bond Lock which cleans and etches. I'm concerned about getting some of this product in the pool water and i'm looking for a safer alternative. I will pressure wash the surface first. The Quickrete people suggested I could use tri-sodium phosphate; would that be harmful if it got in the water? The other alternative I've considered is bleach, to get rid of any remaining organic materials.
    Also, does anyone recommend an alternative to the Quickrete Sealer? I'm not interested in an expensive process - just something I can paint on.
    20,000 gal in-ground, vinyl liner, Hayward DE-3600 filter, Polaris 380, Purex Triton valve 27-1141. North Carolina
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cleaning & painting concrete deck
    You're done SLAMing when:
    Aug 2007
    NC
    27
    Sorry, that response didn't come thru. All I see are a couple of icons.
    Rocklin, Ca
    467
    Mods, or anyone for that matter, will post a blank reply to a topic that didn't get a reply. This moves it to the top of the list so more people see it. This is called bumping.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    This is laborious, I know, but Stegmeier shows this as prep for existing concrete, granted, this is to use their Desert Deck, which you are not contemplating, but anyhow:
    1. Remove any loose material from the existing concrete.
    2. Pressure wash.
    3. Acid wash existing concrete while deck is wet (never acid wash concrete when dry).
    4. Pressure wash a second time.
    5. Scrub deck with Tri-Sodium Phosphate to neutralize acid.
    6. Pressure wash a third time.
    As to the proper product for "painting", I'll get back to you.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Aug 2007
    NC
    27
    Thanks, this is helpful. Any thoughts on the type of acid and the concentration? I have muriatic here.
