Thread: Stenner help needed!
    Nov 2013
    Fort Worth, TX
    114
    I've had a Stenner pump about a year and other than having a ruptured tube about 6 months after my install, all has gone well. I noticed that my chlorine level in my pool was unusually low and checked my pump to make sure it was working. Unfortunately, it is not.
    The pump runs but no fluid is being dispensed. I first unscrewed the fitting for the outlet tube at the pipe and no fluid came out. I then unscrewed it at the pump and still no fluid came out. I removed the strainer from my tank, cleaned it, and put it back in my tank after verifying that the tube was open from the tank to the pump.
    I decided to take the whole assembly apart to clean it and make sure everything is working correctly. However, I cannot get the roller assembly off the shaft. I know it is suppose to be lubricated with Aqualube (or whatever it is called) but I did not have that when the tube ruptured. I have it now, but now I can't get the roller off. I have a spare roller assembly (bought when the tube ruptured) but I need to remove the old one first!
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Dec 2011
    Prosper, Texas
    124
    Re: Stenner help needed!
    Did you verify the black tubing was not cracked or split? This is one of the problems I had run into and I like you did lots of troubleshooting to figure this out. I would try a new tube if you have not already.
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Similar to a problem I had earlier this year. Everything seemed to be working, but no chlorine was being dispensed. I replaced the pump tube and all is working fine. I got about 18 months out of the original tube, but no figure I'll just replace it yearly.
    Support the site
