Results 1 to 8 of 8
Thread: Flint water crisis. Any pool chemistry similarities?
    I've been reading about the Flint water crisis and it sure sounds like the people running the water treatment plant did not understand some of the basic water chemistry that the people on this forum deal with all the time. I am sure methods of treatment are different, but it sounds like the ph of the water from the Flint river was too acidic and because it was not adjusted properly with the right additives, it corroded the protective layer that forms over the lead in the water lines and copper pipe lead solder. The result was that lead leached into the water that people were drinking.
    I am far from an expert on any of this. Any of the chemistry geeks on here have any insight into the matter?
    16x32 Inground Gunite Pool, 1965, renovated, epoxy painted.
    Hayward Ecostar Pump
    6' Conical Franciscan Woodworks Teak Hot tub
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Flint water crisis. Any pool chemistry similarities?
    From what I've seen on TV, it looks like some of the water has a severe Iron problem as well. Likely a result of the same issue of lower pH. Not much to say about it really, but it's a disaster for Flint on several levels. It's my humble opinion that there is more than a low pH issue here, but I don't have enough facts to back that up. It's a little shocking that they didn't foresee these potential problems and more than a gross oversight again, IMHO. Pools are the least concern really, but I'm curious if we see any results from this show up here. If we do, the advice will be much the same as always-metals are tough, and there are only a couple of things that usually help much.
    Essential Links:
    JoyfulNoise's Avatar
    May 2015
    13,244
    Even though people get freaked out by lead solder joints, the fact is that 50/50 Pb-Sn solder is completely stable as long as the pH of the water is maintained in a normal range. When the pH and alkalinity are both too low, the stable lead oxide and lead carbonate passivation layers get disrupted and then lead levels spike. There are many, many, MANY old eastern cities with lots of old copper and cast iron water pipes that are perfectly stable and deliver safe drinking water. Thankfully newer construction uses Sn-Ag or Sn-Sb solders which actually out-perform 50/50 solders.
    There is a very up-to-date Wikipedia entry on the water crisis that goes into a lot detailed history regarding how the city of Flint handled it's water supply and the history of the crisis. It's a very good read.
    Matt
    Thanks, Matt. There is so much misinformation out there on this. I have looked at the wikipedia entry. I am surprised that the city of Flint did not have someone knowledgeable enough to manage the water treatment properly. Apparently the EPA and the Michigan Department of Environmental Quality were in disagreement about the need to add orthophosphate to the water to reduce the corrosivity.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No surprise there.
    Essential Links:
    Jan 2014
    Buckeye AZ
    807
    Would it literally be easier to just build a new town, instead of repiping every single drinking water supply pipe?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    What a mess this is turning into....some really screwed up on this one.
    Essential Links:
    May 2015
    13,244
    Matt
