Results 1 to 8 of 8
Thread: placement of solar (air) sensor for solar heated
    Diver's Avatar
    May 2011
    South of Boston
    450
    I got PentAir SolarTouch controller for my upcoming solar heater and it came with 2 sensors - water and air. The first one is 20' and the second is only 20" - it barely sticks out of the controller, making its placing it very difficult.
    Is it supposed to be exposed to the ambient air only, or does it have to be in the sun when the panels are in the sun? I assume the latter, in which can I'm puzzled by manufacturer's decision to make it so short.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Re: placement of solar (air) sensor for solar heated
    The water temperature sensor gets mounted in the pipe between the pump and filter. The solar temperature sensor gets mounted on a flat surface with the same exposure to the sun as the panels. Ideally, near the panels. Then, you use waterproof connectors to connect to a two conductor cable to get to the controller. Use 20 AWG outdoor rated sensor wiring.
    Support the site
    Diver's Avatar
    May 2011
    South of Boston
    450
    James,
    Thanks for your response. That makes sense, I just don't get why the manufacturer wouldn't include enough cable for both sensors...
    I agree. It would make sense for them to have enough wire for most installations.
    Support the site
    Diver's Avatar
    May 2011
    South of Boston
    450
    It seems that both of the sensors are the same 10K Ohm thermistors, so it's even more strange the way PentAir packages it:
    P/N 520272 - Temperature Sensor replacement kit (for water/air)
    P/N 522101 - Solar Temperature Sensor replacement kit (for solar)
    Is there difference between air and solar? The only difference that I see is that the solar one is black, so it would mimic closer what the panels would experience temperature wise (I think).
    Seems like PentAir could've simply packed two of P/N 522101 but with 20 feet wires and it would work fine.
    I don't need all 20 feet for the water one, so I think I'll cut the wire off of that one and extend the other one with it.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It depends on the installation, for example my solar controller is nearly 50 wire feet from my solar panels so it makes some sense to use a pigtail sensor and add wire as needed. I used relatively cheap low voltage outdoor lighting wire (I think around 16 gauge)
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,236
    I found the manual for your controller at http://www.pentairpool.com/pdfs/solartouchOM.pdf
    It sounds like the 20" is a pigtail and you supply the wire to get to the panels depending on your need. On mine, I needed 70' to put it in conduit and make it tidy.
    There's a humorous line in the solar sensor section of your manual... "If necessary, splice a two-conductor extension wire to the sensor." I can't imagine an installation where 20" would be enough for to get to the roof sensor!!
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,741
    The two sensors are exactly the same. The solar temperature sensor would ideally be located on the roof where the panels are located. In my situation that would require over 150' of wire which probably isn't practical for the manufacturer to provide.
    There is no standard setup for pool equipment and solar heating so it isn't really possible to make something that would meet the needs of every pool.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
