Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: New Here and In Need Of Owner Build Advice
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    I live NE of Atlanta and I'm trying to get started with an owner build pool. I'm wondering what is the best way to get good pool plans? Also, I'm usually a great researcher by nature, but I've been having a hard time finding pool subs for quotes in my area. This forum is a wealth of information and I'm so excited to have found it. I've had many people try to talk me out of pool construction without a pool contractor, but I'm sure this is the way I want to go.
    I am hoping to break ground in March, but I'm nervous about the stand still I'm at already trying to find subs. I welcome any advice you have and look forward to posting pictures of my progress soon!! Thanks!
    Aug 2014
    Northern IL
    4,615
    Re: New Here and In Need Of Owner Build Advice
    Great that you posted here! Let's keep all your posts on this one thread so we can follow you better!
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Okay, I will!
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Good for you for considering an owner build! That's the path we've taken, and so far it's been going well. A little nerve wracking, but we know we are saving money and getting the quality we want, so it's worth it.
    As for finding subs, one way to start is to look up gunite companies, because they are generally listed in the yellow pages or on the internet. Then everyone will start giving you names of subs in the different trades and you can go from there. Whenever you talk to someone, just ask if they have any recommendations for you. Of course you'll still have to do your homework on the names you get, but that gets the ball rolling nicely.
    Good luck and keep us posted! How exciting for your family!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Hi, Jamie! I've seen a few of your posts and I'm excited for you. I can't wait to be at the point you're at. Thanks for the advice...very helpful
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Hi Sheree,
    welcome to TFP!
    Before you go getting quotes from subs, you need to have your pool designed, and be able to show those to the subs.
    Start with hunting for Swimming Pool Architects or Swimming Pool Design or Swiming Pool Plan online or in the yellow pages.
    The pool designer should provide all of the building plans and they should contain enough detial for you to be able to obtain building permits with them.
    The architect will likely be able to recommend you some subs too. (providing your designer is in the ATL area).
    Most of the subs know each other, so once you find the first one, the rest should be easy.
    Good Luck on your project!
    Divin Dave,
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Hi Dave, thanks for the welcome and great advice. Are there typically local pool designers that aren't pool contractors too?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,392
    Sheree! What an adventure you are about to go on! I will be following along to see what happens!
    Kim
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Thanks, Kim! It's getting real and I'm so excited. I'm glad to have found this forum - I've already learned so much from other people's threads. And I'm looking forward to getting everyone's opinions here. I'll post pool plans as soon as I get them
    Aug 2014
    Northern IL
    4,615
    Looking forward to it. So exciting!!!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Hi Sheree! Welcome to TFP! There are quite a few OB on here so you are sure to get great advice!
    I'll be following along! I share your excitement
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Hi, Nini! Your pool sounds AMAZING! I could get myself in trouble on this forum - every day I see more things that I'd like to add to my plan haha! Here is my before picture.
    Aug 2014
    Northern IL
    4,615
    Are you going vinyl or plaster? If vinyl, do you get much rain run-off down that slope?
    Jul 2012
    Tallahassee, FL
    30,392
    Oh my three of my fav. things! A pool build with a kid and dog= a happy Kim!
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Absolutely.
    Many PB's more often than not, will hire a pool designer (engineer) to design the pool, then hire the subs to work from teh pool designers building plans.
    Gunite swimming pools are engineered to withstand the forces of being full of water and not burst. Your building permit folks will require structural designs to review before they will approve a building permit.
    google up 'pool engineering plans' or "swimming pool designers" or something of the sort and you will get lots of hits. Might help you become a bit familiar with the design process before you contact anyone.
    Speaking of permits, some advice. When you start soliciting the electrical work, and plumbing, etc, ask your subs to also include the building permit in their quote. They do it all the time and know the ropes of getting them. For sure, there will be an electrical permit required, and if any of your pool plumbing will be tied into the city sewer, there will be a permit for that too. Depending on your particular municipality (it varies from town to town), you may require a plumbing permit whether its tied into the city sewer or not. The plumbers will know that though.
    Quote Originally Posted by sheree202 View Post
    Divin Dave,
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    For sure! The longer you wait, the more you look, the more EXPENSIVE the build becomes, lol!
    What a great yard for your pool. Looks like you will have a happy kiddo. Does you dog like to swim? He/she is gorgeous!
    Denise-TFP Guide
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    I decided to work with pooleng.com to design my engineering plans. They encouraged me to draw up my plans by hand and emailed me examples. Mine is still a work in progress, but should be done this weekend. Has anyone else done this or does anyone have any improvements I should make? Thanks!!
    Nini, Our dog is an English Retriever so we're hoping she'll swim too!!
    Nectarologist's Avatar
    Apr 2015
    New York
    426
    I love the shape, esp the ends & the corners. My deep end is roman shaped and we put a bench in there. It's perfect to sit and watch the kids swim, you have a straight view of the pool the whole time. I also put a ledge that's about 10 - 12 inches wide so people can stand on it. We get so much use out of the deeper end because of this. We also have two returns in the bench so when the pool heater is on it can be nice to sit in front of to warm up. My yard is also sloped. Do you plan on needing to dig into it or will the pool fit on the level part?
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    JamieP's Avatar
    May 2011
    1,135
    Good for you, Sheree! I looks like you are off to to a great start!
  20. Back To Top    #20
    Jan 2016
    Las Vegas Nevada
    280
    Welcome to the O/B world. Keep at it and you will learn some great stuff off of this site. I met an awesome guy that just did his pool that lived right by me off here. Has been a ton of help. One thing I did learn is call excavating company for bid and ask for other subs they use. Then do with another excavator and so on. Then ask the plumber and he will give you names and ask the next plumber for a list. You will get a great list together in no time.
    16.5x37 free firm Gunite pool with 14 foot wet deck. Wet edge satin matrix Aqua blue pebble finish. Pentair 2hp variable pump. Pentair 540 cartridge filter. Pentair salt system. Pentair led lights 2 large 1 small. Intellibrite 5g controller. 1200sqft concrete decking.
