Results 1 to 13 of 13
Thread: ph vs TA My Battle
    Apr 2013
    Sacramento, CA
    2,769
    ph vs TA My Battle
    My TA was hovering around 60 all summer long. After woring all fall to bring it up I have it and the pool stable at TA of 90 and ph of 7.8. Its held this for a month without any additions of baking soda or MA.
    Should I just leave it here or try and get the TA up to 100 and the ph down to 7.5?
    This morning
    FC 5
    CC 0.5
    TA 90
    PH 7.8
    CYA less than 25
    Ch 660
    Right now I get a CSI of .35. If I reduce to 7.5 it makes a clear difference but I can't get it to hold there and my TA jumps around
    Jan 2013
    Long Island, NY
    184
    Re: ph vs TA My Battle
    Curious, if you had no problems with a TA at 60 for the duration of the summer, why do you want it higher than 90 now? Ph rise a lot less with a lower Alk.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Apr 2013
    Sacramento, CA
    2,769
    Because the TFP guidelines call for a higher TA.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,764
    Disregard what is called for as that is not necessarily correct. Raising your TA and lowering your pH is a recipe for an endless roller coaster of acid and baking soda additions.
    Raising your TA is only going to cause your pH to rise higher and faster and high TA with low pH only further increases pH rise. A TA around 60 is ideal in my opinion since the pH will rise very slowly and that coupled with a pH of 7.8 is fairly close to being at equilibrium for the carbon dioxide content of the water and air (outgassing being the major contributor to pH rise) .
    Are you finding your TA dropping? How are you chlorinating? Why is your CYA so low?
    How is your TA jumping around? That isn't really possible unless you are influencing it somehow.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Your pool has shown you it's "happy place". Listen to your pool and let it ride.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Agreed, TA at 60-70 is fine if PH is stable. TA only needs to be raised if PH is erratic.
    30,432
    The attempt to precisely define TA levels for all situations doesn't seem to work well. As Kim says, your pool is stable and happy.....leave it alone.
    CSI and the numbers we suggest are pretty solid indicators but the stability of your pool water is the best indicator of all.
    Hi-jacking just a bit......Why is your CYA so low?
    Apr 2013
    Sacramento, CA
    2,769
    Rain and overflow drops it some. Also my CYA tends to drop during the winter.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    As others have said, listen to your pool. My pool really like my TA in the 40 - 50 range. If I go above 60 I'm adding acid every day to keep the pH in check.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by tim5055 View Post
    Ditto, and my high calcium not only makes me need it here, it allows it to work for me. Situations are not the same for all users.
    Essential Links:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,764
    How are you able to maintain a TA in the 40's? I imagine you'd have to use borates for stability, but a TA of 40 with just about any other numbers makes the CSI VERY negative.
    -Brian-
    POOL BUILD
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,027
    If it ain't broke, don't fix it.
    Divin Dave,
    May 2014
    Franklin, NC
    9,216
    Quote Originally Posted by bdavis466 View Post
    No borates. With a dog and five cats that think it's a big water bowl I won;t take the chance.
    I keep the pH at the upper end of the scale and my CSI is around -.3 As the water warms up the CSI moves closer to "0"
    Support the site
