Results 1 to 19 of 19
Thread: Leak at the top of the tile
    Dec 2015
    Orlando, FL
    41
    Central Florida
    10k gallon in-ground
    Generic Pebble-tek with a course of tile
    Mostly, my pool keeps a nice water level; no observable leakage. But, even very heavy rainfall will not elevate the level over the top of the tile, which leads me to believe there is a significant leak at the top of the tile.
    My question is... should I even be concerned about this? In practice, it's kind of nice because I don't have to drain it down. But I don't know where all that water is going and if it might be causing some unseen damage.
    Thoughts? Thank you.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Leak at the top of the tile
    Could we get a picture? The whole pool and some of the tile.
    Do you have a overflow drain? It will be a small 1/2 inch pipe in the middle of the tile line. It could look different that is why a picture would help?
    Were you there when they built the pool? If its not a drain you are not aware of I'd really like to see a picture of the pool.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,424
    I am thinking what they said ^^^^^^^^^^^ You have a overflow drain that you do not know about. Here is hoping!
    Kim
    Dec 2015
    Orlando, FL
    41
    Thanks for the help! I'm not sure pictures will give enough detail, but here are a couple. The tile looks to be contiguous, i.e. no jets, breaks, any visible plumbing. The water level goes completely to the top of the tile. There are three inlet jets, each about an inch below the tile; one skimmer; one suction cleaner port several inches below the tile; as well as a light one foot below and a main drain. That's the sum total of visible breaks in the surface.
    I was not the original owner, but I did have it resurfaced/retiled when I bought the house a year ago.DSC_0031.jpg
    Jul 2012
    Tallahassee, FL
    30,424
    Very interesting...........so no holes right where the water stops at..........hummmmm guess we need to play detective.
    Okay so you say the pool will NOT overflow even with heavy rain (and we DO get some heavy rain in FL!) when it rains it goes to ------------the top of the tile and not past it......
    Can you talk to the people that replastered and tiled your pool? I would be interested in what they had to say.
    I know it is cold so will not ask you to get in the water LOL See if you can look at above the tile where the water stops all around the pool to see what it looks like.
    Is it soft in any spot? Is there a slit or something that could let water out above the tile?
    I would talk to the people who redid the the plaster and see what they say.
    Hey you have been there a year.......has it ever overflowed?
    Kim
    Dec 2015
    Orlando, FL
    41
    Quote Originally Posted by kimkats View Post
    Right. We haven't had a real rain for awhile, but it goes quickly to the top and I've never observed it above that line.
    I'm completely not kidding when I say the last I saw of my resurface guy - one man shop - was his mug shot on the local news. Other than that, I'm happy with the job he did.
    Will do.
    No. If it's a leak at the tile line, it's fast enough to keep up with the heaviest Florida monsoon.
    Thank you for your help.
    30,403
    You don't mention skimmers nor do I see them. Does your pool have them?
    Jul 2012
    Tallahassee, FL
    30,424
    Good catch Dave!
    Sandy can you please add your pool info. in your siggy? (Settings in the upper right corner, edit signature on left hand side).
    info needed:
    pool surface type and size, filter type, pump type, test kit using, how adding chlorine.
    THANKS!
    Kim
    Dec 2015
    Orlando, FL
    41
    I did say in Post #4 that there was one skimmer. Its bottom is about even with the lower edge of the tile.
    Sorry about the Sig info - I don't see where to add that with Tapatalk, so I'll log into a web page and update it.
    Surface is generic Pebble-tek, 10k gallons, in-ground, cartridge filter, 1hp Sta-rite single speed pump, chlorine using 3" tabs Pentair chlorinator augmented with liquid to keep CYA under control. Taylor test kit K? using powder.
    30,403
    Sorry I missed the skimmer. I would either find the leak or make sure I ran the pump to drain water from the pool when necessary.
    If the water stops at the very top of the tile, then that's where the leak is.
    Incidentally, your pool looks overfull in the pics. Do you keep the level about 1/2 way up the skimmer?
    Jul 2012
    Tallahassee, FL
    30,424
    I am following on build thread and his overfill outlet is RIGHT UNDER The coping. It is oval in shape. I think if you were not in the pool looking for it you might miss seeing it. Signed the contract this morning, New build Orange County, CA - Page 9 It is post 169. He has a tape measure by it.
    Kim
    Dec 2015
    Orlando, FL
    41
    It's hard to be certain without getting into the water, but I looked very closely and see no sign of an overflow outlet.
    I think in the pics, the water is just about half-way up the tile, but coincidentally, we had two hard storms in two days, so the level is up now. But it hasn't gotten quite to the top of the tile.
    So, assuming no purposeful overflow solution, is water egress, from random areas over the tile, a problem to be avoided?
    Jul 2015
    Central Valley CA
    1,107
    Do you have an auto fill (round lid that looks like a skimmer cover with a float valve inside)? My auto fill canister has an option for an overflow inside the canister up above the float valve is a plug with 3/4 socket that a PVC pipe can be glued into. Or builder did not use this option so the plug is still in place. If yours has this option perhaps the builder took advantage of it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2013
    Sacramento, CA
    2,769
    So it appears the pool is "leaking " between the top of the tile line and the bottom of the coping. Is that correct?
    I can't tell is that coping part of the deck that is just etched and colored or it is separate from the deck?
    If the coping and the deck are the same that is the "leak". If that is how the pool is built than that is not a leak. That is a consequence of design. You need to keep your pool level within the tile line or as Dave states halfway up the skimmer. Allowing the pool to overtop the tile line can cause unseen problems and degradation of the material under the deck surface.
    Dec 2015
    Orlando, FL
    41
    No, no autofill. Nothing at all out of the ordinary.
    @gwegan - the deck is an acrylic surface, all one piece from the top of the tile, going up about 4" and horizontally for several feet. The coloring you see is on the surface. I'm not understanding the difference between the two styles you reference - did I tell you enough to answer your question?
    Thanks everyone.
    Apr 2013
    Sacramento, CA
    2,769
    I think you have a pool deck that rides over your bond beam. Your pool may be "leaking" at the joint between the top of the bond beam (which usually corresponds with the top of the tile) and the deck. The coping is structurally part of the deck. Close up pictures would help.
    If that is true then your pool is "leaking" through that joint. Now when the pool was constructed that joint was sealed. But that joint has a lot of movement because the large deck expands and contracts with temperature so that joint rarely stays sealed. If the pool is allowed to go over the tile line it seeps through this joint in multiple locations and your pool only fills to the top of the tile line.
    This may cause long term degradation of the material under your deck, or it may do nothing.
    The solution is to not let the pool much above halfway up the skimmer inlet or the tile line. As a secondary defense you can re seal or re caulk the joint. But that is a secondary defense and no matter what you use it will only last a few years because there will always be deck movement.
    Again some close up pictures of the top of the tile line would help.
    Dec 2015
    Orlando, FL
    41
    Here's a closeup.
    It sounds like the deterioration of the seal is very likely over time, in this case 21 years. And prevention by monitoring the level is the most practical solution, and lastly, is advisable because damage is possible.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Also check your skimmer for an overflow. Some have a knockout for overflow built in.
    https://www.hayward-pool.com/pdf/lit...LITSKIMC15.pdf
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Apr 2013
    Sacramento, CA
    2,769
    You can seal the joint I'm talking about clearly in this picture. Here it looks in great shape but it only takes a small crack to result in a large volume leak. But I can't rule out something in the skimmer as suggested above.
    Keeping the pool level about halfway up the skimmer is what you need to aim for.
