Results 1 to 8 of 8
Thread: Cl460 leaking at oring
    Nov 2015
    Carrollton tx
    451
    The filter has been leaking a little since I bought the house
    this week I opened the filter and cleaned it and closed it - still leaks
    the oring was no longer round - when I lubed it up the leak reduced a little but it still weeps
    ive ordered replacement oring and replacement stainless retaining ring
    i hope that both will fix leak issues
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Nov 2015
    Carrollton tx
    451
    Re: Cl460 leaking at oring
    Well New oring is arriving a day early
    if it warms up some more Ill change it and see
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Are you using a silicone based lube on it ??
    Solar Blanket, Well Water, Borax Added. 76°
    Dec 2014
    Riverside California
    482
    In addition to lubing the O-ring make sure that there is no dirt or debris in the channels both on the lid and the body of the filter where the O-ring seats. Be sure to tap the clamp with a rubber mallet as you tighten it to help seat the O-ring. Don't beat the snot out of the clamp with the mallet, just some firm blows all the way around the clamp several times as you are tightening it.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Nov 2015
    Carrollton tx
    451
    as stated in OP using lube
    Previous owner left leslies pool lube
    thats what I used
    The seat and the oring were clean
    The new oring is here
    waiting on the stainless backing ring to arrive and ill try again
    Need to buy a mallet
    second time today it came up
    Nov 2015
    Carrollton tx
    451
    Well today warmed up and I installed the new stainless retaining ring,SKU: R0405200 and oring
    the previous suggestions of the rubber mallet seemed pointless because before the ring the clamp tightened down easy and the halves met easily
    after installing the retaining ring, which is better described as a structure ring since all it does is keep the composite parts round. (It just slides down into the lower half of the filter with some gentle taps.)
    The hammer suggestion makes sense when all the parts are there.
    with the new ring and new oring, I had to lube the clamp, lube the bolt and generously tap the clamp to get it to tighten.
    since it ran with no retaining ring for so long I didn't tighten the clamp all the way to 1/16". There is still 1/2 inch gap, but the clamp was straining and I didn't want to break anything
    Nov 2015
    Carrollton tx
    451
    NO leaks - woo hoo
    Aug 2014
    Northern IL
    4,615
    Congrats!!!!
