Results 1 to 8 of 8
Thread: Dolphin Nautilus Plus - if you have one, how long does the Cycle run?
    Jun 2012
    Lafayette, Ca / USA
    260
    Just purchased a Dolphin Nautilus PLUS on Amazon. Aside from no option at purchase time to get the correct Brushes for my Fiberglass IG pool, the cleaning cycle seems to be 2 hours and not the 3 as advertised. I initilly thought it was because the Filters clogged - and in fact the 1st run they were very dirty. So I cleaned them & ran it again. Same thing - about 2 hours in it stopped (the Light remains on though). So cleaned again, somewhat dirty again. Ran a 3rd time & again, 2 hours it stopped - filters NOT dirty.
    How long does yours run for the cleaning cycle? Does the Light on the power unit actually go OUT when done? My power light remains ON when the unit stops moving.
    (I find the Manual that came with this not very thorough - nor is the one online at Maytronics).
    Thanks in advance.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Dec 2014
    Riverside California
    482
    Re: Dolphin Nautilus Plus - if you have one, how long does the Cycle run?
    I do not know what to tell you about the cycle time, it would be worth a call to Maytronics to find out. I have a Dolphin Triton Plus and my power supply blue power light also stays on when the cleaner has reached the end of its cycle. One tip, if you do not have a caddy be sure to put something on the bottom of the cleaner when storing it so that the tracks are not bearing the weight of the unit.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The maytronics website says the Nautilus Plus cycle time in 2.5 hours.
    Nautlius PLUS - Maytronics US, Inc
    The regular nautilus cycle time is 3 hrs.
    Divin Dave,
    Jun 2012
    Lafayette, Ca / USA
    260
    Quote Originally Posted by Divin Dave View Post
    This says 3 Hours > Amazon.com : Dolphin 99996403-PC Dolphin Nautilus Plus Robotic Pool Cleaner : Patio, Lawn Garden
    (you have to scroll to the bottom to see the side by side for the 2 models)
    Hmmm.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    welp, there is certainly some descrepancy it seems. Why is anyones best guess. Maybe someone else with the Plus will chime in with how long theirs runs.
    Divin Dave,
    Jun 2012
    Lafayette, Ca / USA
    260
    Yea, certainly differing information. I also would be curious to hear from anyone that has the Nautilus PLUS as to how long their's runs. I confirmed that there is nothing stuck in the propellers as well. I also would have expected the Light on the Power Unit to go out when the cycle ends. Mine just stays lit when the unit stops running. And honestly, the Product Info & Instructions are really lacking for this expensive unit. Thanks !
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    The power light staying on after the cycle ends is normal. It wont go off unless you push the button. Mine does that too.
    And I agree, the paperwork isn't the greatest. Seems like that's the norm for just about any product related to swimming pools, not just cleaners.
    Divin Dave,
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks - much appreciated.
