Thread: Liner Replacement advice?
    Feb 2015
    wilmington, nc
    7
    My liner is shot, seriously faded and leaking in a number of areas. I've had two pool companies each say come spring i need a new liner.
    Any advice or words of caution. Anything you wish you had done when you replaced a liner?
    Thanks.
    35,000 gal. / Vinyl / Sand Filter / Taylor K-2006 Test Kit / No SWG / Direct Sun / 8' Deep / Coastal NC
    Aug 2014
    Shallotte, NC
    693
    Re: Liner Replacement advice?
    If you liked the liner you had, there may be a sticker on the back side that allows you to reorder an exact duplicate.... or at least the size that you originally had.
    Installing a permanent pump in your hydrostatic well, if you have one, is also a pretty good idea, assuming you have high groundwater. My liner started to float, when if flooded in Columbia, SC at the beginning of October...
