Results 1 to 8 of 8
Thread: How to calculate volume?
    new-to-poolcare's Avatar
    Aug 2015
    Bellflower, CA
    19
    How do I estimate the number of gallons in a pool with an irregular shape? Thank you.
    26,000 gallon, in-ground concete; Pentair Superflo VS pump; Pentair Quad D.E. Filter; Polaris 180 Vac-Sweep with booster pump
    Aug 2014
    Shallotte, NC
    693
    Re: How to calculate volume?
    Break it down into smaller more manageable geometric shapes. Rectangles, circles, ovals, etc.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    My last pool was shaped like that.
    Go to the pool math page and below the main chart is an estimator.
    I used that and came up with 23,000 gallons initially....then when I noted free chlorine level changes when
    adding bleach...over about 2 months I nailed it down to 19,000 gallons.
    Every time I added chlorine or other things like calcium, it turned out 19,000 is what it was.
    My current pool is 13,000 gallons. Although the hand written paper work says 16,500.
    But my estimates (same as i did before) came up at 13,000 according to pool math
    and when I add chlorine the pool math is correct...so in my mind it is 13,000
    A friend of mine has a pool just like yours looks (bigger than my old one but longer) and he claimed it was 30,000 so
    you might be very close.
    Dolphin E10 Cleaning Robot.
    JoyfulNoise's Avatar
    May 2015
    13,262
    You could also use this chemical method developed by onBalance -
    A Chemical Way of Calculating Pool Volume
    Matt
    Aug 2014
    Houston tx
    2,525
    Pentair also has a pool volume calculator.
    Pool Volume Calculator | PENTAIR
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    I've done this, and I will say it's works great, but I would suggest it only to the more experienced. Someone who has titrated many, many endpoints on the TA test.
    Essential Links:
    Aug 2015
    Bellflower, CA
    19
    Thank you so much. This method is excellent for my pool.
    Last edited by new-to-poolcare; 01-30-2016 at 07:06 PM. Reason: I think I replied to thread by mistake.
    Aug 2015
    Bellflower, CA
    19
    Quote Originally Posted by Marlahoutex View Post
