Thread: Flo error
    Jan 2016
    Buchanan MI
    1
    Flo error
    I have a,2003 Sundance cameo hot tub. I recently replaced the circulation pump on it when I was getting g error. Now error is back but the pump is running. Tell flow switch is opening and closing lie it should. Could tell switch just be bad. I've tried running without telling filter also and error still comes on
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Flo error
    Welcome to the forum Jason.
    I'm sorry, but I can't quite make out what all you are asking.
    Essential Links:
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Flo error
    " I've tried running without telling filter also and error still comes on "
    Did you try running it without the filter ??
    How does the force of the water feel coming out of the jets ??
    Solar Blanket, Well Water, Borax Added. 76
    Jun 2015
    Guntersville, AL
    5
    Re: Flo error
    Had a similar issue with my Sundance tub as well. Ended up taking the garden hose and running some water into the outlet where the heated water comes out for a few minutes (without pump running of course). You have to hold the hose nozzle against it to force the water in. That cured my FLO error.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Flo error
    That could have been caused by air in the plumbing lines. My hot tub specifies to fill it by putting the hose in the filter housing to push the air up and out of the plumbing. Some people have been able to bleed the air out of their plumbing by opening unions inside their tub. Others have had to drain and refill through the filter.
