Results 1 to 12 of 12
Thread: how many cups of calcium chloride (hardness up) equals 1 pound?
    Dec 2015
    arlington, tx
    100
    this information is not listed on the bucket.
    also, will this product raise the pH?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: how many cups of calcium chloride (hardness up) equals 1 pound?
    3 cups is about 30 ounces by weight (using Pool Math). That's about 10 ounces per cup. So... one pound would be about 1 and 2/3 cups. Or you could just use a scale...
    Isolated Spa - 345 Gallons
    Dec 2015
    arlington, tx
    100
    don't have a scale that small
    No need to be exact. Just estimate the amount based on the container weight and amount. In other words, figure out the percentage and guestimate from there.
    Calcium chloride won't chemically raise the ph. However, I have seen some ph rise in some cases, which I suspect might be due to carbon dioxide offgassing as the chemical is added. Possibly due to the creation of nucleation sites, which is how the coke and mentos reaction happens. Note that this is just speculation.
    Support the site
    Dec 2015
    arlington, tx
    100
    my wife found a food scale. 2 cups is one pound. so i added 2 pounds today. baseline CH level is 190 and pH is 7.7. i'm trying to get CH up to 250. ill post here if pH rises. thanks for everyone's help.
    Two pounds will only raise the calcium level by 8 to 11 ppm in 20,000 gallons.
    Support the site
    Oct 2015
    Katy/Texas
    411
    Sneak up on your target Calcium level. It easy to overshoot.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Dec 2015
    arlington, tx
    100
    ok on sneaking up. i've calculated that overall i'll need approx 15 lb hardness up to raise CH by 60ppm
    Dec 2015
    arlington, tx
    100
    Ph is still 7.7 from yesterday, so the little bit of calcium chloride i put in didn't affect pH. i put 5 more pounds in this morning.
    the extended test kit directions section of this site (http://www.troublefreepool.com/threads/24188-Extended-Test-Kit-Directions)
    doesn't mention anything about water temperature when performing the CH test. does the water sample need to be warmed up before performing CH test?
    Dec 2015
    arlington, tx
    100
    chem geek, in another thread, has probably already answered my question:
    (from 3/5/09): Re: Effect of Temperature on Calcium Hardness Reading
    I E-mailed Taylor about this and they said that you should not be using the Calcium Hardness test (or any other test) above 100F. The tests are designed and calibrated for room temperature. Richard
    Dec 2015
    arlington, tx
    100
    CH is 230ppm this morning using warm and cold water samples.
    i added 4 more pounds of hardness up.
    Dec 2015
    arlington, tx
    100
    CH is now 250ppm using cold water sample.
