Thread: Concerns with install solar during winter?
    Mar 2015
    Las Vegas NV
    460
    I'm ready to install my solar but not sure if I should do it while we could still have a couple of days below freezing left this winter. I suppose they would install, test, then could drain, right?
    Input greatly appreciated!
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Oct 2014
    Sacramento, CA
    72
    Re: Concerns with install solar during winter?
    We have installed plenty of solar in the winter as long as they drain the pipes after it is tested you will be fine
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
