Results 1 to 8 of 8
Thread: Pool Automation: Hayward, PENTAIR, or Other?
    Jun 2015
    Terry, MS
    6
    I have already decided to convert my pool to salt water this spring but am now also looking at the possibility of pairing the SWG with an automation/control system. I see that both PENTAIR and Hayward produce an "all in one" control system but haven't been able to find a lot of reviews on either of the systems. Does anyone have any input/advice on which system is more reliable, cost effective, etc?
    Also while I am on the topic is it worth the money to include chemical control or are the pH and alkalinity easy enough to manage once converting to SW?
    Size: 26,000; IG, Vinyl; Sand; Age: >5 yrs
    Dec 2014
    Riverside California
    482
    Re: Pool Automation: Hayward, PENTAIR, or Other?
    I have a Pentair Easy Touch automation system, along with the Pentair Screen Logic so I can control everything from my PC or phone and I love it! I recently had my Screen Logic adapter go bad, and after talking to Pentair, they send me a new one the same day, no charge. The day after, I was back up and running. As far as I am concerned, Pentair has good customer service. Can't comment on Hayward because I do not have any of their equipment.
    From what I have read on these forums, PH automation is problematic. For acid injection I would recommend using a Stenner pump. I use a Stenner pump for chlorine injection and it works great.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's pretty much a Ford/Chevy argument but I like Pentair.. And others say that Jandy is more the Cadillac. Then for heaters, it's Raypak(Rheem) then Pentair. If you are considering one these consistently bring the best reviews. Prices for comparable equipment will be pretty similar and competitive. Opinions will vary on some of this, just like cars and trucks.
    Essential Links:
    Jun 2015
    Terry, MS
    6
    Thanks guys, right now I am leaning towards the Pentair EasyTouch 4 function 40k gallon unit (Model# 520593). Is this the correct size system for my pool or will I only need the 20K gallon system?
    JoyfulNoise's Avatar
    May 2015
    13,239
    Advice on an SWG - get the BIGGEST one you can. So for Pentair, that's an IC60.
    My opinion on chemical automation is this - don't bother. Stay away from ORP chlorine control as it is highly problematic and acid injection is a "nice to have" kind of thing but really not necessary. Remember, the more probes, pumps, canisters, etc., you add to your pool pad, the more things to break and need fixing.
    Matt
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,533
    People tend to like what they have, so I like Pentair. But, whatever you buy, you need to make sure that all the parts play nice together. It makes sense to me, that the SWG, the Controller, and a VS pump should all be able to talk with one another. I've seen several posts where people have bought components from different manufacturers and then can't understand why they can't control them they way they want.
    Dec 2014
    482
    Quote Originally Posted by jmccro89 View Post
    I would go with the Easy Touch 8 instead of the Easy Touch 4. As you get into automation, you will think of even more things you want to automate such as landscape lighting, etc. For each of these things, you will need another relay. Four is just too limiting.
    Jul 2014
    Bedford, TX
    7,533
    As a follow on to Gary300's input... An EasyTouch 4 is actually only an EasyTouch 3 as one of the 4 relays is dedicated as the Pump/Filter circuit. That only gives you three Aux relays. One for your pool lights, one for landscape lighting, and one for a pad light.. I have a pretty simple pool, so three is enough for me. I do recommend the Screen Logic, which allows control of your pool from your PC or Phone. I received one for Christmas and I love it....
