Thread: Find a Spa in Smallest size
    Dec 2015
    Largo, Florida, USA
    13
    My friend has a small backyard. She want a Spa for her backyard. How small a Spa could be found. backyard is almost 2.3 meter wide.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Find a Spa in Smallest size
    There are fairly small models, that are rated for 2 people, just be aware that spa ratings are very optimistic. I have an older Hot Spring Jetsetter spa which is rated for 3 people, but in reality it is a 2 person spa which measures about 82x62 inches (2.08 m x 1.57 m) in a rectangle Mine is a 1998 model, which is 2 design changes ago, the newer Jesetter models are slightly larger 84x65 inches I think (redesigned in about 2008 and again in 2015). There are also 2 person triangluar corner spa's that are even smaller like the Hot Spring model TX (heart shaped seating with a wedged V shaped common foot well). The TX measures 5'8.5" x 5'8.5" x 29"H (1.74m x 1.74m x .74mH) these lengths are on straight side toward the corner, the other side of the triangle bows outward.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    This thread is closed. They were a sneaky spammer!
