Thread: How do I make coping to deck joint space when pouring deck
    Mar 2015
    Bossier City, LA
    13
    Part of my deck has sunk due to poor planning from the original design. So I have a deck that has tilted down hill. Tried jacking it up, but it would not stay where I put it. Plus it slid back away from the coping! New concrete going to be poured. There's not one straight edge on this pool so I have no idea how to create a joint space between the coping and the concrete form on the curved side. What do builders use?
    16,000 gallons. Gunite/Plaster. BBBM method. Sand filter. Polaris "Sputnik" cleaner tank.
    Nov 2013
    Central Texas
    113
    Re: How do I make coping to deck joint space when pouring deck
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    Mar 2015
    Bossier City, LA
    13
    Perfect, Thank You!
    30,403
    I assume you are fixing the substrate so the new concrete stays in place.
    Mar 2015
    Bossier City, LA
    13
    I was going to put gravel down but I'm all for hearing suggestions.
    The real issue was erosion of the soil...I think.
