Thread: Spillover not working in auto mode
    Sep 2015
    Avondale, AZ
    87
    Hi guys,
    I bought a house a few months ago with a pool and raised spa. The control board was set to kick the filter on around midnight. It ran in spillover mode for about four hours, then switched to low speed spillover for a few hours, and then to just spa for another hour or so. Well, I wanted to shorten the time a little bit since it's winter and that seemed like overkill...
    Since I tinkered, it longer spills over. It runs just pool for the allotted time, and then spa. But no spillover. I checked and double checked but I can't figure it out. Clearly I screwed something up. Turning it on manually, all zones work the way they should. Spillover is not disabled on the control board.
    Anyone have any ideas?? Thank you in advance!
    Approx 25k gallon PebbleTec in-ground diving pool and attached raised (10 person?) spa, with spillover and waterfall.
    Hayward AquaLogic PS-4 control board, Hayward SP3400VSP Ecostar pump, Hayward C5520CP cartridge filter, Hayward H400FDN 400k BTU NG heater
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Re: Spillover not working in auto mode
    Do you have the spillover scheduled to come on for a certain time period?
    Did you change pump speeds?
    Typically with the automation systems, when there is more than one program scheduled, whichever program has the higher speed wins. Can you post a little more info about the scheduling/speeds?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Sep 2015
    Avondale, AZ
    87
    I didn't change any of the programs, I don't think, I just changed the times. The one there, I think says hi speed-all. That's the first one, then there's low speed-all, then the spa one.
    I didn't change any speeds that I'm aware of.
    Thanks!
    Sep 2015
    Avondale, AZ
    87
    Quote Originally Posted by bdavis466 View Post
    THe spillover was coming on. It was the first automation. Spillover from approx 12:15 AM - 4:15 AM. To my knowledge, I didn't change that.
    Sep 2015
    Avondale, AZ
    87
    Is it even possible in auto mode to run spillover for a certain period of time and then just pool (so the popups can do their thing) for another period of time??
