Thread: Why shouldn't you use Trichloro-s-triazinetrione tablets in hot tub floater?
    Jan 2016
    Crownsville, MD
    10
    Hi I'm new to the world of hot tub ownership. I've been trying to gain knowledge on hot tub water treatment and care.
    Is it commended not to use trichloro 1' tablets in floaters in a hot tub due to it being stable form and rising the CYA to high overtime?
    Are there any non-stable dichloro/trichloro tablets on the market or do most just use liquid bleach once CYA levels are normal levels?
    Thanks
    2015 Bullfrog A8
    540 gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Why shouldn't you use Trichloro-s-triazinetrione tablets in hot tub floater?
    There is cal-hypo that is stabilized with calcium but that will raise your CH. Most use bleach. I have been using this process in my tub for a little over two years and it works great, How do I use Chlorine in my Spa (or pool)?. More on various forms of chlorine here, Pool School - How to Chlorinate Your Pool
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by v4kerker View Post
    ...<snip>...
    Thanks
    If it is a pill or a powder, it is stabilized.... with something. The general opinion, in this forum, is to add only what is needed to your water. If you need sanitizer (only), that pretty much excludes solid materials, because they add other chemicals, as well..... thus, not recommended. However, if you choose to use powders and pills, the only down side is managing the effects of the stabilizer.... which can be time consuming and expensive.
