Thread: Both main pump and cleaner pump are not pumpingul
    Jan 2016
    Fort Worth texas
    2
    We just purchased a house with a pool about three weeks ago. The main circulating pump and auto pool cleaner pump were working. Today they run, but there is no output. I thought that the water may be down enough to loose prime, but after adding water (just an inch or two) there is no change. Any suggestions on what I can check.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Both main pump and cleaner pump are not pumpingul
    Check to see if the skimmer baskets and/or the pump strainer basket is clogged with leaves or debris. Also, check the filter pressure gauge to see if the pressure has risen.
