Thread: Polaris connector issue
    Dec 2013
    Augusta, GA
    96
    I noticed today that the wall connector for my Polaris 280 is broken and needs to be replaced. If I order this part from Amazon:
    Amazon.com : Zodiac D29 UWF Quick Disconnect Replacement : Lawn And Garden Tool Replacement Parts : Patio, Lawn Garden
    and use the pressure relief valve from my broken connector pictured here:
    will that cover everything I need to make this fix?
    Also - what is the best way to remove the broken piece of the connector from the hose?
    Thanks
    IG gunite pool / 30,000 gal / 20'x 40'/ built mid 70's
    1.0 HP Hayward Super pump / Polaris PB4-60 booster pump
    Pentair SD-80 sand filter
    Intermatic mechanical timer (PF12222TB)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Polaris connector issue
    Not sure how they come assembled, but perhaps a bump will get this seen by others who have.
    Essential Links:
    Jan 2011
    Richmond, Texas
    595
    I think that is it. I had to replace mine and that looks about right.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Oct 2015
    Katy/Texas
    411
    Cut the hose.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    I would suggest getting part number 9-100-9001 UWF Connector Assembly. That way you have the whole assembly.
    Support the site
