Results 1 to 7 of 7
Thread: addition order for restart after water replacement for CYA reduction
    Apr 2014
    Venice Florida
    24
    Is there a particular order that chemicals should be added in when restarting after pumping down 35% of the water to reduce CYA?
    Pool home in Venice Florida. No pool home upstate NY. Retiree from Navy Nuclear Power Design Laboratory.
    9500 gallon plaster pool. cartridge filter, pentair vs pump, fafco solar heater.
    New to the pool thing. Learning.
    Part time requires a pool service for pool maintenance.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,186
    Re: addition order for restart after water replacement for CYA reduction
    Quote Originally Posted by Ed Buell View Post
    Not really. If the pool was balanced before you replaced the water it will probably be "fairly" balanced still. FC & CH will go down. Depending on the fill water pH & TA may go either way.
    I would probably do it in this order, but others will have their opinions (which may be better than mine).
    FC
    pH
    CH
    I generally don't chase a TA "perfect" number, so I'd probably not worry about that for a few days.
    Support the site
    Aug 2014
    Northern IL
    4,615
    What's your new CYA number? Just curious.
    Apr 2014
    Venice Florida
    24
    My target is 45 - 50. When I bought my house 2 years ago it was 160. So I did two major drains last year to get it to 55 or so. We are snowbirds so the pool is maintained by the pool guy who generally runs the CL injector. so after 6 months away it was back to 80 or so. Its going to be cool for a couple days, so I'm doing the drain now so as soon as it gets refilled I can turn on the solar heater and get the water up from 72 deg. now to around 84 or so which is usable for us. Anyway. Its half way down. Then we refill into tomorrow and start to restore chemistry.
    thats the story.........I target a little less than 50 because it will go back up over the summer, when I'm not here.
    Aug 2014
    Northern IL
    4,615
    When it's full again, if you want any help with your numbers, let us know!
    Apr 2014
    Venice Florida
    24
    Well, pumped down around 38% or 3600 gallons and refilled. Can't wait for my water bill.....
    results CL <.5, pH stll around 8, CH 225, TA 90 (expected it to drop)..., and CYA is now around 45, which is about on target.
    calculated adds with pool math
    added CL, Acid, and CaCl2. so will let it stir for a while and test again later today.
    but all in all, a successful partial drain....unfortunately the solenoid valve in my solar heater hasn't cycled so its pretty cold.
    Hope they can come today and check that out..........I need to get some heat in there.
    May 2014
    Franklin, NC
    9,186
    Well, you know you need acid and chlorine.
    Changes in TA may or may not happen depending on the fill water.
    Treat your pool as if the CYA is 50. There is no 45 on the CYA scale and as it is a non linear scale, half way between 40 - 50 is not 45, so just round up for determining your FC level.
    Support the site
