Results 1 to 10 of 10
Thread: New pool owner
    Nov 2015
    Boston, MA
    120
    New pool owner
    I have to update my signature but we have a new inground pool we had put in this past fall. I have a swg but have not installed it yet. I bought the test kit you folks recommended. My question is what chemicals do I need to buY to make adjustments to the water chemistry when the nice weather rolls in?
    For example baking soda, ph up, ph down, what do I buy to adjust ph, calcium, etc?
    Is there a list of things I should buy for balancing? Is there a place online I can get it all?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: New pool owner
    You can buy most everything you need at Walmart. Reading Pool School over and over will answer all your questions!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    30,421
    Re: New pool owner
    Your first step should be to determine what and how much you need. If you don't test first, you will waste a lot of money.
    So break out that test kit and tun the tests and post the results up here......that's the first step.
    Nov 2015
    Boston, MA
    120
    Re: New pool owner
    Cool, will do. I assume get it balanced then install the swg? The skimmers still have the liner over them, they have to cut out the liner around it when they open the pool. Can I install the cell and flow switch but not hook it up to the chlorinator box before they open it up since there's no water in the plumbing?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: New pool owner
    Congrats on the new pool!
    Start here, Pool School - ABCs of Pool Water Chemistry
    Nov 2015
    Boston, MA
    120
    Re: New pool owner
    Thank you
    Nov 2015
    Boston, MA
    120
    Re: New pool owner
    Any response to my question about installing the swg cell?
    DFW, TX
    24,497
    Re: New pool owner
    Yes, it will be fine. It is sitting in the box without water in it. Mine was installed for weeks without water.
    Nov 2015
    Boston, MA
    120
    Re: New pool owner
    Yes its in the box, so I can install just tge cell before they open up the pool?
    DFW, TX
    24,497
    Re: New pool owner
    Sure.
