Thread: Water level high in agp before freezing temps
    May 2015
    NW Indiana
    22
    The water level in my agp is about level with the skimmer bottom. And on top of the winter cover there's a layer of about 4-6 inches of water and ice. Should I lower the level of water on top of the winter cover or the water off the pool, or both? And in which order if it makes a difference. Temperatures are forecast to drop to 20 and I want to avoid damage to cover, skimmer, etc. Any advice will be appreciated.
    19K gal AG. 200 Swimpro Element Filter. 2HP, Dual Speed Voyager. TF-100.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Water level high in agp before freezing temps
    Sounds like you don't have a cover pump to keep it drained off. Do you have any flotation pillows or anything under the cover in the middle to help give it like a tent peek to help it drain off?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I would not want ice to get high enough to get in skimmer. Seen pictures of damage.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    wjr75's Avatar
    Jun 2013
    IL
    836
    Do you have the skimmer face plate on? If so I wouldn't worry.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2015
    NW Indiana
    22
    Quote Originally Posted by woodyp View Post
    I do have a pillow under the cover and I just used a manual pump to drop the water level about 2" below skimmer. I hope this will be enough to keep ice from skimmer.
    I just wasn't sure if removing water will settle the ice and pull down on the cover. I'll just keep an eye on the tension ofthe cover's cable and make sure is not pulling the walls inwards.
