Results 1 to 8 of 8
Thread: desert air system
    Oct 2015
    geneseo,il
    2
    desert air system
    HELP; Building is up and getting ready to dig pool. Sounds crazy, but this way was able to work thru winter months. Building is 36'x60' with 18'x44'x4' pool. Will have bathroom, shower and mechanical room inside. South and East side are all 5'x6' windows and French doors. Ceiling will be stained and sealed car siding. Please see pictures. Was told by pool builder that I needed a Desert Air System to control humidity. It is sounding very intensive and extremely expensive. I am an amputee and wanted a pool to swim and work out in year around located in the Midwest. What have others done.
    18'x44'x4' IGp vinyl / 30,000 gallons - enclosed in 36' x 60' pool room - 1hp sp pump - DE filter - salt water system
    30,414
    Re: desert air system
    I think you should listen to your PB......assuming this is not his first indoor pool.
    Humidity control is mandatory in an indoor pool so it should come as no surprise, really.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    You ARE going to need something to control the humidity. I don't know anything about the systems but I bet you could do a search to find out more about them.
    Kim
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Also understand that "Desert Aire" is a brand name. A little time using Google will provide additional companies that supply this type humidity control equipment.
    Support the site
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Tim5055 is correct. Essentially you will want a 4-coil dehumidifier system if it is a fully enclosed room. An indoor pool room is more complicated (and more expensive). It is not just a room that happens to contain a pool.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Nov 2011
    Moberly,MO
    1,010
    Consider an automatic cover as this will help control humidity and evaporation from the pool when you are not swimming. You will definitely have to have a dehumidification system.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jun 2017
    Davenport, IA
    1
    Katilguy, Hi I am in Davenport, Iowa. Wondering what your experience has been so far? I can't open your attachments but we are thinking of building similar or buying a house that already has an indoor pool.
    Oct 2015
    geneseo,il
    2
    pool was finished 06/16 in time for father's day. it has been one year and only chemical i have had to add has been muriatic acid. Desert Aire system works almost to well. Keeps humidity down around 20%. We keep pool at 88* and room at 82*. This is a salt water pool with salt generator. covered when not in use.will try to post pictures of finished project.
