Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Black Algae & Balancing
    snichols1219's Avatar
    Jan 2016
    Missouri City, TX
    34
    I am about to tackle the black algae that has taken up roost in spots in my pool. It all started when the salt cell went out at the start of last summer and the chlorine level dropped to zero multiple times. Not only was the pool store wrong about the diagnosis that my salt cell was fine, they were also wrong that is not black algae ~ I have tried everything they recommended and nothing has worked. I have already read about how to go about tackling this, but before I start, just want to confirm that the pool should be in balance before starting it?
    Thanks for any help!
    Shannon
    ~ 22,000 gallons, gunite, white plaster, 22'x38' freeform (103' pb) 3'6" shallow 7'0" deep
    Aquarite Generator, Hayward cartridge filters, Hayward Northstar 1.5 hp main pump,
    Waterfall/slide/bubblers with dedicated pump, Polaris 280 vacuum, Hayward 400K BTU heater
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Black Algae & Balancing
    Hey Shannon,
    Welcome to TFP!
    Yep, that's how BA gets a foothold...consistent low Chlorine. You'll need to balance for sure, and you should begin a SLAM procedure once it is. First, do you have a good test kit, and have you begun reading any information here? I would suggest starting with the ABCs in Pool School first thing. Let us know about your test kit, and we can begin helping you get started on killing the BA. Just know, that BA will take time to kill completely so you'll need some patience for sure.
    Essential Links:
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Shannon
    What Patrick said is good advise. With a good testing kit you can handle it yourself and not end up in a cycle of getting "Pool Stored".
    Solar Blanket, Well Water, Borax Added. 68
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,387
    HI! We have your back in this battle with BA.
    Make sure you have a good brush for you pool as that will help quite a bit also.
    Kim
    Jan 2016
    Missouri City, TX
    34
    Thanks for the quick response! I wouldn't consider the test kit we have to be a "good" one, it's just a basic one ~ uses the drop solution for chlorine & pH not the strips. I have been reading the forum for a while now, just have never signed up or posted until now. I'm heading off to the pool store to get the proper brushes and have the water tested so I can get it balanced and get the process started! What type of test kit do you recommend I pick up?
    Quote Originally Posted by Patrick_B View Post
    Hey Shannon,
    Welcome to TFP!
    Shannon
    Jul 2012
    Tallahassee, FL
    30,387
    Look in my siggy for where to buy a GREAT test kit.
    You are going to need to buy the TF-100 XL. If you do not you will run out of the test stuff during your battle.
    I would not put much stock in what the pool store says. They are there to make money from you. We are here to help you get your pool right for the least amount of money possible.
    I would start looking around your area to see where YOUR best price and availability for chlorine or bleach is. For some it is Wal-mart, other the pool store.
    Just make sure it is fresh and plain bleach (no smells or splashless) and the % is listed. Walmart's Greater Value is 8.25% and has a high turn over so should be fresh.
    You are going to need a LOT to beat the BA.
    Kim
    Jan 2016
    Missouri City, TX
    34
    Just ordered the test kit. Obviously I'm not going to have that to check it today, so I will have the pool store check it and then post my results. I know my pH is high and most likely with all the rain we have been getting I need stabilizer, phosphates will also be high because of all the leaves we still have falling around here. I won't do anything else until I post the results and get y'alls advice on where to go from there. I am also going to get the proper brushes while there to start brushing. Should I go ahead and turn the generator up to 100%?
    Thanks!
    Quote Originally Posted by kimkats View Post
    Kim
    Shannon
    Oct 2015
    Katy/Texas
    411
    Hold off buying any chemicals from the pool store.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jul 2012
    Tallahassee, FL
    30,387
    You have a solid plan! Do not do anything without running it by us! LOL
    You can turn your SWG up BUT it will NOT be enough AND it will wear out your cell faster.
    It would be much better to get some bleach and add a jug a day until your test kit gets there.
    You can get a simple PH test kit for right now if you want. Walmart sells them sometimes.
    You are NOT going to worry about your phosphates right now.
    The only things you will worry about is your PH and FC until your test kit gets there.
    Kim
    Jan 2016
    Missouri City, TX
    34
    Okay, just got back from the store. And all was I expected ~ EXCEPT that I currently have ZERO chlorine (water is crystal clear)! Grrrrr! FAC 0, CYA 20, pH 8.2, phosphates 2500. So, I need to add the conditioner to keep the chlorine from burning off, right? Without doing this first, me pouring a gallon of bleach in a day is pointless, right? All of this rain this week has also tanked my salt level once again, so I need to add a couple bags to bring it back up. Gotta love El Nino!
    Thanks!
    Kim
    Shannon
    Jul 2012
    Tallahassee, FL
    30,387
    Shannon hold off on the CYA (conditioner) as that is the test the PS seems to get wrong the most.
    When you do a SLAM to clear algae the amount of chlorine you use will depend on your CYA. The higher your CYA the more chlorine you will need so..........at least you have some CYA but not too much for the SLAM.
    I would work on your PH right now. It might even be higher than 8.2 as that is about as high as the test goes.
    One thing FC over 10 will mess up your PH test. So get your PH down to 7.2 and start adding chlorine.
    Kim
    30,402
    Shannon,
    Slow down just a bit. I know you are ready to defeat this problem but please start with VERY solid footing.......and that solid footing is test results from your kit that's on the way.
    You have had this problem a long time, please wait another couple of days and get precise results with your kit so your initial doses will work as expected.
    While you are waiting, I suggest you put a small bottle of Clorox in the pool each evening until you kit arrives.....it's cheap insurance.
    Jan 2016
    Missouri City, TX
    34
    I got the wire brushes and brushed the pool this afternoon. I added 2 bags of salt to get the level back to where it should be and the acid to get my pH down (I have a basic kit and will check that level tomorrow). Before the sun went down I added a bottle of bleach as suggested.
    Shannon
    Jul 2012
    Tallahassee, FL
    30,387
    You go girl! Just what you needed to do for now!
    Okay here are some links you need to print out and read.
    Print these out:
    Pool School - Chlorine / CYA Chart
    Bookmark these:
    THIS is the one you will need when you get your test kit:
    Pool School - SLAM - Shock Level And Maintain
    It is a lot to take in. Read them a little at a time. I had to reread so of them several times for them to sink in. Once you get your test kit it will make even more sense.
    HUGS!
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your Salt generator may not work much or at all if your water temp is near 50 or below. In fact it may not come on at all if the temp is too low. Don't add any more salt yet either. No more than a jug of bleach every other day until your kit arrives just to be safe. I really think it's great you want to jump on this, but waiting for solid test numbers is the best approach. A couple of days more wait won't make a difference on this, do just try to be patient. Use the time to educate yourself even more in pool school. It sounds like you're off to a great start with that, so keep it up.
    Essential Links:
    Jan 2016
    Missouri City, TX
    34
    Funny, I had already printed out what you suggested, including the ABCs of Pool Water Chemistry & the SLAM. I'm keeping it in a binder in the garage with the rest of my stuff. My new test kit should be here tomorrow! In the meantime I have gotten the pH down to 7.2 and have been brushing with the wire brushes and adding bleach. Just getting the top layer off has already made it look so much better ~ especially on the tanning ledge and top step of the deep end where I can really reach it well instead of having to use the pole.
    Print these out:
    Bookmark these:
    HUGS!
    Kim
    Shannon
    Jan 2016
    Missouri City, TX
    34
    I've been watching the temp and it seems to be holding about 54, according to the panel it's generating. The salt I added got me back to where I needed to be, so no need for any more. And only adding bleach every other day.
    Thanks!
    Shannon
    Jan 2016
    Missouri City, TX
    34
    Okay, my kit got here (that thing is awesome!). I tested everything and got it balanced.
    FC 10
    CC 0
    CH 250 (question about this)
    TA 150
    CYA 70
    Dumped in the initial mass amount of bleach last night to bring it up to shock level. So now I need to check daily the FC level, keep it at the shock level, and brush with the wire brushes until it's no more?
    As far as my CH goes (which I know I'm not concerned with at the moment, asking for reference when I'm done here) isn't that low? According to the pool store report 200-400 (they also said it was 250) is okay, so I'm in level, but reading in the ABCs for a plaster pool with a SWG it should be 350-450.
    Thanks!
    Shannon
    Oct 2015
    Katy/Texas
    411
    You should test FC frequently so you can add additional Chlorine throughout the day. The closer you maintaine the shock level, the quicker you will get done.
  20. Back To Top    #20
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Agree, check the FC every hour or two and add bleach to bring it back up to where it needs to be.
    If you can, go ahead and turn off your SWCG as at this point you need massive amounts of chlorine and all the SWCG is add is minute amounts. Save the life of the salt cell.
    Support the site
